Author Topic: Starting Amps Required for a 1998 115 hp Evinrude  (Read 3590 times)
April 24, 2012, 03:23:37 PM
kraw2
Re: Starting Amps Required for a 1998 115 hp Evinrude
« Reply #15 on: April 24, 2012, 03:23:37 PM »
Thanks Blue,
2 gauge has been orderd from Genuinedealz.com. That's where I get all my other items from.
April 24, 2012, 03:33:59 PM
« Reply #16 on: April 24, 2012, 03:33:59 PM »
Quote from: "kraw2"
I used the Blue Sea Calculator with 120 amps @ 20 ft. run. It recommends 1 gauge cable for the allowable 3% voltage drop.
If you use those numbers, a 2AWG will give you a 3.2 % drop. I'd say that's close enough. This was run on the GD calculator. 1Awg would equate to 2.6% so I'd say running 2AWG is just fine based on your numbers by using the calculator (both BS and GD calcs are the same, with BS using the complete circuit and GD using one way)
Quote from: "kraw2"
SeaBob recommends 2 gauge.
Enough said.
November 22, 2013, 05:21:03 AM
« Reply #17 on: November 22, 2013, 05:21:03 AM »
Kraw - how did it work out for you?  Did you measure the actual cranking amps when you used the 2Ga?  Can you do this? This info would finish this thread up.
