Author Topic: Fairing/ filling materials?  (Read 1167 times)
April 22, 2012, 11:12:39 AM
Read 1167 times
ceejkay
« on: April 22, 2012, 11:12:39 AM »
looking for advice on fairing.. thickened resin is a pita to sand(cabsoil).. anyone find anything better to use to fill in holes or to fair before prime/paint??
April 22, 2012, 01:39:01 PM
Group W Bench
Re: Fairing/ filling materials?
« Reply #1 on: April 22, 2012, 01:39:01 PM »
For pinholes and small imperfections, Duratec high build primer works very well and is quite easy to sand. For big dips, I like to use Chem E APF-7. It is a very rigid filler that sands easily.
April 22, 2012, 01:52:52 PM
ceejkay
« Reply #2 on: April 22, 2012, 01:52:52 PM »
yea im not so worried by pinholes, but mostly old screw holes.. do you have a links for Chem E APF-7? i cant seem to find it..
April 22, 2012, 02:38:13 PM
Group W Bench
« Reply #3 on: April 22, 2012, 02:38:13 PM »
I think it's made by Axson. I will check our invoices on Monday and give you the details. If you need, I can order a gallon for our Thursday delivery and send to you. Please note that you use the cream hardener with this product, not MEKP.
April 22, 2012, 03:25:53 PM
kraw2
« Reply #4 on: April 22, 2012, 03:25:53 PM »
If you already have the epoxy use fairing filler instead of Cabosil.
April 22, 2012, 03:33:05 PM
dirtwheelsfl
« Reply #5 on: April 22, 2012, 03:33:05 PM »
Add micro balloons in with the cabosil. About a 3:2 cab to mb ratio. It makes it sand way easier.
April 22, 2012, 03:58:39 PM
« Reply #6 on: April 22, 2012, 03:58:39 PM »
be sure to use a mask with the micro balloons.  you dont want to breath that stuff!  But it's light and sands easy.
April 22, 2012, 06:14:58 PM
Capt Matt
« Reply #7 on: April 22, 2012, 06:14:58 PM »
Awlfair
Light tackle sportfishing
April 22, 2012, 11:42:52 PM
pbustle
« Reply #8 on: April 22, 2012, 11:42:52 PM »
Evercoat makes a polyester fairling filler that is easy to sand and easy to mix.  You can get it at most auto body shopes.  workes great for filling chips and small items.  I would not try to use it to fill large areas.
Pat Bustle
Yacht & Ship Broker
United Yacht sales
http://www.unitedyacht.com/pbustle
pbustle@unitedyacht.com
1988 170 Aquasport - 1996 130HP Evinrude
1974 19-6 Aquasport - Upside down \":-|\"
1982 50\' Hatteras Convertible
April 23, 2012, 10:22:02 AM
CTsalt12
« Reply #9 on: April 23, 2012, 10:22:02 AM »
Formula 27.  Super easy, dries fast and hard
Jimbo
1989 175 Osprey
April 23, 2012, 07:57:47 PM
ceejkay
« Reply #10 on: April 23, 2012, 07:57:47 PM »
thanks guys ill look into all that
April 24, 2012, 12:58:09 PM
gman 82 aquasport
« Reply #11 on: April 24, 2012, 12:58:09 PM »
Got my flairing compound at uscomposites.com..Stuff looks like bondo when you open part A, but it is epoxy based, part B looks like "Crisco"  :o all white and creamy, mixes 2(part A) to 1(part B), very easy to spread thin and easy to sand :) , I flaired the edges of my new floor (about 6inches on floor and 8 inches up the wall) and then flaired the entire floor of my 19-6 and still have about 1/3 bucket left( started with 1gal size).Comes in 2 seperate pails, hardens in about 20 minutes so you have good working time, sandable in about 2 hours.. :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
