Author Topic: 240 seahunter  (Read 1600 times)
April 19, 2012, 08:06:17 AM
Read 1600 times
Luv4paws2
240 seahunter
« on: April 19, 2012, 08:06:17 AM »
I am contemplating buying one :). It is between this and a 222 12deg. Can anyone tell me what differences there are ie deadrise, gunwale height, beam, besides the obvious 2' longer. I have read both that they are the same and that they have slight differences. Thanks
April 19, 2012, 09:45:37 AM
Re: 240 seahunter
« Reply #1 on: April 19, 2012, 09:45:37 AM »
Hiya, welcome!
We don't have many on here. The deadrise is 12 degrees. Gunnel height would speculate is the same as a 22-2.
Best looking boat AS ever made IMHO.
April 19, 2012, 10:32:01 AM
Luv4paws2
Re: 240 seahunter
« Reply #2 on: April 19, 2012, 10:32:01 AM »
Thanks. The one I am looking at is a 74 and appears to be in decent shape, it is 2 hours away from me so I want to make sure it is what I am looking for. It was an I/o but has no motor. I am also concerned about weight, it has no trailer and the only one I have to transport it on has a single #3500 axle. Without a motor, outdrive, and many other components, will it be too much for the trailer?
April 19, 2012, 11:00:37 AM
Re: 240 seahunter
« Reply #3 on: April 19, 2012, 11:00:37 AM »
This is a 71 (your model type is unknown) but it gives you a fair idea what you may be dealing with.
http://www.classicaquasport.com/gallery ... oc&cat=564
Single axle trailers in my experience aren't generally used for 24' boats (think too short) and reviewing the weight of the hull, you're kinda pushin' the envelope but hey...
People do "different stuff" all the time. :|
April 19, 2012, 12:22:20 PM
Re: 240 seahunter
« Reply #4 on: April 19, 2012, 12:22:20 PM »
Yep I'm with Bob, a tandem would be better. Can you borrow/rent one?
The boat dry would be OK on a 3500# trailer....but make the assumption the stringers are soaked, the floor and transom wet, that's gonna add some serious weight.
If you wanted to chance it, move the winch stand forward.
If its like most, would like to see you get in it for 1K or less....JMHO.
April 19, 2012, 03:09:47 PM
Re: 240 seahunter
« Reply #5 on: April 19, 2012, 03:09:47 PM »
A 240 SeaHunter will go 3500 lbs easy with rigging - even without it - that would be very borderline on a single axle trailer - how about brakes?  You can go, but can you stop?
April 20, 2012, 10:00:51 AM
Re: 240 seahunter
« Reply #6 on: April 20, 2012, 10:00:51 AM »
The 240 Sea Hunter was the forerunner of all the deep-V Aquasports.  The 240 hull was  also used on the first XF and FF models, and later on the CCP.  10" draft was advertised with an 8 foot beam.  The original 240 Sea Hunter had a 20" transom height - and needed that spashwell.  That did not last long, and the transom went up to 25" pretty quickly.  Power was I/O from 155 to 180 HP (165 Mercruiser was probably the most popular I/O), or single or twin outboards - twin 115s were very popular on that boat, and a single 235 JohnnyRude was also popular (remember those?).
Options included a full camper canvas that allowed the 6'5" side seats/bunks to be used for overnighting and a tower.  The optional tower for the Sea Hunter was also kept around and available on the 246CCP and even offered on the 222CCP starting in 1981.
April 20, 2012, 02:39:40 PM
Luv4paws2
Re: 240 seahunter
« Reply #7 on: April 20, 2012, 02:39:40 PM »
Thanks for the info, but now I am really confused. I thought the deep v's were 19 degrees. I am almost certain (without measuring myself) that this one is 12 degrees.
April 21, 2012, 08:55:55 AM
Re: 240 seahunter
« Reply #8 on: April 21, 2012, 08:55:55 AM »
Deadrise on a 240 should be 19-20 degrees.  The 10" draft for the Sea Hunter was the same as the later 246CCP and the 222CCP.  Check out the ad from 1971 where Aquasport refers to the hull as a "modified deep-V" - the others were semi-V at 12 degrees or almost no deadrise in the case of the flatbacks.
http://www.classicaquasport.com/gallery ... 71&cat=564
April 25, 2012, 12:06:56 PM
orb
Re: 240 seahunter
« Reply #9 on: April 25, 2012, 12:06:56 PM »
I have an early 70's 240 seahunter that I am working on. It is 14 degrees at the transom. A little more than the 22-2, but not really a deep vee.
70\'s  240 seahunter(rebuilding now)
Photogallery-
http://www.classicaquasport.com/gallery ... &protype=1
\'77 22-2 (rebuild on hold)
1997 19\' sundance 70 merc
