Author Topic: mercruiser 165 (chevy inline 6 250) to mercruiser 4.3  (Read 783 times)
April 17, 2012, 06:59:53 PM
Read 783 times
gcurrence
« on: April 17, 2012, 06:59:53 PM »
i tryed searching to see if this has been discussed before but im not a good searcher so i only made it so far, so I thought i would ask, I have a 1976 22-2 cuddy with the mer. 165 inline 6, the 165 is worn out and its time to be freshened up, im going to spend some good money on a mechine shop and gasket kits and everything eltes that a fresh motor needs, I have been tolds that the bell housing from my 165 will fit the 4.3 v6, i dont have a problem moving the front motor mount but how about the throdle controls and the exhaust connections, im not in need a power gains, though it wouldnt hurt, the 165 is easy to work on, how about the 4.3? has anyone done this with positive outcomes? thanks alot for the help,
April 17, 2012, 09:32:08 PM
Re: mercruiser 165 (chevy inline 6 250) to mercruiser 4.3
« Reply #1 on: April 17, 2012, 09:32:08 PM »
I would stay with the inline 6.  An inline 6 is an inherently balanced engine, whereas the 4.3 has to use some work to make it somewhat smooth.  Balance is better on the I6 and everything will fit.  Go to a 5.7 V8 if you want to change...
April 18, 2012, 04:12:04 PM
gcurrence
« Reply #2 on: April 18, 2012, 04:12:04 PM »
are the throdle cables the same? does the exhaust port though the transom need to be replace sence there will be 2 manafolds or do they meet and go though 1 exhaust port, does the transom mount for the 165 work with all mercruiser blocks? i guess those are the main things i would be concerned about, everything eltes would be wiring, fuel, and outdrive ratio, i have the 1.65 now i think i need to gear it or 1.50 if i put the 5.7 in,thanks
April 19, 2012, 05:20:33 PM
« Reply #3 on: April 19, 2012, 05:20:33 PM »
Quote from: "gcurrence"
Throttle cable might change depending on how tight it is now.
You would need a Y adapter to connect the twin exhaust outlets together into a single.
Outdrive/transom should be the same, but you may need a different driveshaft.
Outdrive ratio can stay the same, just change prop pitch to make up for any difference between your 1.65 and a 1.47 that would probably be the preferred ratio.
You might find a deal out there somewhere:
http://www.ebay.com/itm/5-7-Mercruiser- ... 3a736851e9
Got the bucks?  Buy the whole package new and bolt her in:
http://www.ebay.com/itm/NEW-Mercruiser- ... 5d3154edc3
