Author Topic: Anchor ball  (Read 762 times)
April 17, 2012, 04:47:51 PM
Read 762 times
Anchor ball
« on: April 17, 2012, 04:47:51 PM »
Just wanted to know how many of you use the anchor ball method of retrieving your anchor?  If you do how do you like it and do you have any advise on the subject.  Amy said I can get some gear for the boat for my b-day and an anchor ball is on my list.  What would be a good size ball for my use?  18"?
Thanks!
April 17, 2012, 04:50:19 PM
Re: Anchor ball
« Reply #1 on: April 17, 2012, 04:50:19 PM »
Bruce mine never leaves the boat, accept for a pic :D  I consider it a must have.
this is my setup, the buoy model is NB50 and it is almost 50" around
April 17, 2012, 05:45:13 PM
Re: Anchor ball
« Reply #2 on: April 17, 2012, 05:45:13 PM »
OK so that would be a 15" diameter ball.  That is good since I didn't want to try to find a place to store some huge ball.  I have the ring and snap already.  Thanks!
April 17, 2012, 05:59:14 PM
Re: Anchor ball
« Reply #3 on: April 17, 2012, 05:59:14 PM »
Quote from: "Circle Hooked"
X2 - a must have.  Besides in those deeper depths your current windlass might pull a munity. :salut:
April 17, 2012, 07:11:28 PM
Re: Anchor ball
« Reply #4 on: April 17, 2012, 07:11:28 PM »
We use 'em up here all the time grouper fishing. Makes life a lot easier :cheers:
April 17, 2012, 10:34:01 PM
Re: Anchor ball
« Reply #5 on: April 17, 2012, 10:34:01 PM »
I like mine so much I did not let it go with the boat.  I usually don't fool with it in < 50' but when this old man gets tired it sure is nice.
I think the NB50 is what I have too.
April 17, 2012, 11:08:15 PM
Group W Bench
Re: Anchor ball
« Reply #6 on: April 17, 2012, 11:08:15 PM »
Wingtime,
If you are using a Delta or CQR type anchor with some heft, the 18"-20" ball and larger ring have an easier time getting over the transition from rope to chain at the end. If you use a Danforth or Fortress, the smaller ball and ring should be fine. FISH over by Bay Pines has pretty good prices on balls and rings.
April 18, 2012, 12:39:49 PM
Re: Anchor ball
« Reply #7 on: April 18, 2012, 12:39:49 PM »
Right now I have a Danforth type anchor but that may change.  I'm thinking of rolling my own mighty mite anchor for reefs.  I have the ring and such already just need the ball.  Good point on Fish over near the VA I didn't think of them.  They usually have a huge one hanging out front!
April 18, 2012, 01:26:40 PM
dburr
Re: Anchor ball
« Reply #8 on: April 18, 2012, 01:26:40 PM »
So I thought to myself, If space is an issue, why not go with a number of smaller polly balls? That way when not hauling anchors they could be used as fenders...  A quick look at the math and the idea isn't as good as it sounds.. 1 15 inch ball has a volume of 1767 cubic inches, to get the same with a 10 inch ball you need essentially 4..  Great for fenders but where do you stow them? Oh well.. :oops:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
April 18, 2012, 01:47:50 PM
Re: Anchor ball
« Reply #9 on: April 18, 2012, 01:47:50 PM »
I even thought about deflating the thing and just having one of those cheap 12v compressors that I can plug into the cig lighter.
April 18, 2012, 02:15:48 PM
Re: Anchor ball
« Reply #10 on: April 18, 2012, 02:15:48 PM »
I've got a big one, it stows underway between the rail and FWD gunwhale cap, just jammed in there, always use in deeper water.  Also, be careful using the mighty might or any grapplin anchor, they have a tendancy to poke a hole in the ball if it is coming up too fast when it flips into the ring....... don't ask how I know... :mrgreen:
April 18, 2012, 02:29:24 PM
Re: Anchor ball
« Reply #11 on: April 18, 2012, 02:29:24 PM »
Marc so if I'm picturing this right in my head you stuff it under the rail and top of the gunnel... just behind the first stantion aft of the pulpit?
April 18, 2012, 02:46:51 PM
Re: Anchor ball
« Reply #12 on: April 18, 2012, 02:46:51 PM »
Quote from: "dburr"
db, the biggest downside would be dragging the rig back to the boat
April 18, 2012, 03:09:42 PM
Re: Anchor ball
« Reply #13 on: April 18, 2012, 03:09:42 PM »
Look up on the bow in this video. You'll see what Marc is talking about.
http://s669.photobucket.com/albums/vv60 ... EO0054.mp4
April 18, 2012, 04:24:45 PM
dburr
Re: Anchor ball
« Reply #14 on: April 18, 2012, 04:24:45 PM »
Quote
"gran398"
Yet another reason that it ain't the best idea I've ever had!!! :lol:  My wife says she is quoting from  Napoleon Dynamite every time she says” IDIOT!”, now I am beginning to wonder…
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
