Author Topic: Anhyone use a Humminbird thru hull transducer?  (Read 591 times)
April 11, 2012, 06:41:31 PM
Read 591 times
imonna 19 6
  • NorthEast
« on: April 11, 2012, 06:41:31 PM »
hi all,
I have a transom mount humminbird and I am two for two on hitting something and busting the bracket for the past two seasons.   the sound has a lot of debris and I am thinking about going to a through hull version.
Anyone have any experience with them on an aquasport?
Bill
Bill
1979 19\'6" with a 99 Johnson 100
"Pull the Plug"
Northern CT
April 12, 2012, 10:25:33 AM
Re: Anhyone use a Humminbird thru hull transducer?
« Reply #1 on: April 12, 2012, 10:25:33 AM »
I'm running a thru-hull dual frequency transducer on one of my boats now.  No problems with it - I'm running it low in the bow and used a 20 degree transducer to make up for the angle.  It shoots through the glass and gives a solid reading at any speed.  It's nice reading the depth under the front of the boat versus the stern.  Only negative is you lose temp reading, so I installed a separate temp sender.  Humminbird now makes one with a temp sender on a pigtail that would work well:
http://store.humminbird.com/products/313994/XP_9_20_T
April 12, 2012, 12:21:08 PM
imonna 19 6
  • NorthEast
« Reply #2 on: April 12, 2012, 12:21:08 PM »
where did you locate it left to right?    Did you go in the middle ?
nevermind, humminbird doesnt make a shoot through hull for my version unit.
Bill
"Pull the Plug"
Northern CT
April 13, 2012, 11:28:13 AM
« Reply #3 on: April 13, 2012, 11:28:13 AM »
Bill - which model 'bird do you have?  :scratch:
April 13, 2012, 05:44:55 PM
imonna 19 6
  • NorthEast
« Reply #4 on: April 13, 2012, 05:44:55 PM »
a side scan, which the humminbird rep said doesnt have a shoot through hull model.
specifically its a 798 CI SI
Bill
"Pull the Plug"
Northern CT
April 14, 2012, 10:54:18 PM
« Reply #5 on: April 14, 2012, 10:54:18 PM »
No side scan shoot-thrus yet.  You could try an epoxy build-up on a transom mount if you are mounting in on a flat area.  Before doing that, do a clay dam, fill it with water, stick the transducer in the "pond" and see how it works.  This is the best way to check out a transducer location before actually commiting to something that's harder to reverse.
