Carl another tip on primer bulbs is how you hold them while priming. If you hold it with the arrow down the check balls will not seat and it will not pump. As already mentioned if there is air in there holding it arrow down or even horizontal it may not pump at all. You will find it will pump and prime MUCH faster if you hold the bulb arrow up while you prime it. This allows gravity to help seat the check balls in the valves.
neg dude. there must be some sort of check valve int he carb inlet. see, if I disconnect it from the engine, I can put my finger over when I let go of the bulb, forcing fuel into the primer bulb. if I keep my finger on when I let go, fuel comes up to it, i can put it on the engine, and it fired right up. problem is, when the fuel gets out of the carbs after a few days, it won't prime because there is nothing holding air from going back into the primer bulb.
Has the fuel line between the bulb and the tank been replaced? How about the 90 degree fitting on the tank?
