Author Topic: At ramp, can't get pressure in fuel lines.  (Read 1658 times)
April 10, 2012, 08:14:59 AM
Read 1658 times
fmaster360
« on: April 10, 2012, 08:14:59 AM »
Been pumping for 10 minutes. Please help. The primer bulb isn't getting hard.
Carl
\'00 Osprey 205 w/ 200hp Ocean Pro
April 10, 2012, 08:28:05 AM
Re: At ramp, can't get pressure in fuel lines.
« Reply #1 on: April 10, 2012, 08:28:05 AM »
1) is there gas in the tank?
2) has the bulb been recently replaced?
April 10, 2012, 08:46:39 AM
Skoot
« Reply #2 on: April 10, 2012, 08:46:39 AM »
Get a new fuel bulb, and/or check for any pinhole leaks in or around the primer bulb.
1975 19-6 - 90hp Tohatsu
April 10, 2012, 08:50:10 AM
« Reply #3 on: April 10, 2012, 08:50:10 AM »
Quote from: "Blue Agave"
As in "is it installed in the correct direction"?
It happens, that's why BA asked.
Might be the infamous stuck check valve on the fuel pickup (if you have one).
April 10, 2012, 08:53:25 AM
fmaster360
« Reply #4 on: April 10, 2012, 08:53:25 AM »
I think it's the check valve. Got it started though, I'll get some more info to you all later. Thanks!
Carl
April 10, 2012, 10:10:07 AM
« Reply #5 on: April 10, 2012, 10:10:07 AM »
Carl,
Didn't you change the Fuel/water seperator filter?  If you didn't get the new filter completely filled before spinning it on you probably had an air lock in the line, the primer bulb can be a real PIA if your trying to suck fuel from the tank through the filter if the filter had air trapped in the top at the manifold.
April 10, 2012, 11:09:12 AM
« Reply #6 on: April 10, 2012, 11:09:12 AM »
Carl another tip on primer bulbs is how you hold them while priming.  If you hold it with the arrow down the check balls will not seat and it will not pump.  As already mentioned if there is air in there holding it arrow down or even horizontal it may not pump at all.  You will find it will pump and prime MUCH faster if you hold the bulb arrow up while you prime it.  This allows gravity to help seat the check balls in the valves.
April 10, 2012, 12:07:33 PM
« Reply #7 on: April 10, 2012, 12:07:33 PM »
Quote from: "wingtime"
At Stamas, where I hung almost Exclusively Yamahas, we installed our bulbs in the bilge.  Yam was VERY strict on making sure we oriented them vertically, arrow facing up...
April 10, 2012, 01:06:00 PM
« Reply #8 on: April 10, 2012, 01:06:00 PM »
That is great advice guys. Always wondered why on the jon boat sometimes it was impossible to prime, other times easy.
April 10, 2012, 03:18:32 PM
« Reply #9 on: April 10, 2012, 03:18:32 PM »
Try a little WD40 on the oar locks. :idea:
April 11, 2012, 09:23:36 AM
« Reply #10 on: April 11, 2012, 09:23:36 AM »
April 11, 2012, 10:01:45 AM
« Reply #11 on: April 11, 2012, 10:01:45 AM »
I know.
I need help.
Sometimes replies do something to me I can't describe.
I realize it's not the reply but rather me.
That sense of worthlessness I feel is all consuming at times but....
I'm trying to improve and admitting one's problem is the first step, still.....
Derail?
How 'bout Deplane, Deplane. :mrgreen:
April 11, 2012, 10:28:46 AM
« Reply #12 on: April 11, 2012, 10:28:46 AM »
:lol:
Same here.  I just could not resist.
April 11, 2012, 11:54:46 AM
« Reply #13 on: April 11, 2012, 11:54:46 AM »
:lol:  :lol:  :lol:  :lol:
(Hey just upped my post count, again)
 :lol:
April 11, 2012, 06:08:18 PM
ceejkay
« Reply #14 on: April 11, 2012, 06:08:18 PM »
silly question but is there fuel dripping out of the carbs? i had this happen to me and after ruled out the common bulb issue found that 2 of my floats were stuck down
