Author Topic: Need Some Carb Help  (Read 796 times)
April 09, 2012, 03:35:52 PM
Read 796 times
Need Some Carb Help
« on: April 09, 2012, 03:35:52 PM »
I need to know what this part is called, it's off my 15 hp Yamaha you can see it's all cracked, the rebuild kits I have seen don't seem to have this.
The part resides in here.
Thanks for the help.
April 09, 2012, 05:15:44 PM
Re: Need Some Carb Help
« Reply #1 on: April 09, 2012, 05:15:44 PM »
HArd to tell by the pic but I'd almost say that is an accelerator pump diaphragm.  Does the rod get pushed in by the throttle?
April 09, 2012, 05:17:15 PM
« Reply #2 on: April 09, 2012, 05:17:15 PM »
Well,
I'm no piston head but I love a good mystery so.....
I'll guess (I always do). :idea:
It looks like a diaphragm used on a CV carb. The 2 CV (upside down in photo) hints at this. I didn't know they used CV type carbs on outboards and I don't know if this is really one but.....
Looky here- #10 maybe
http://www.yamahaoutboardmotorpart.com/ ... _-_2002%29
My experience with CV carbs are from motorcycles and the diaphragm controls a needle that moves the slide in relation to the change in pressure that occurs when the actual throttle moves the butterfly valve. Your photo doesn't look like the carbs I'm used to in the motorcycle world but I'm thinking this is the part you may be looking for.....
EDIT: Wing's pump idea makes more sense. Looks like it somehow is pushed by the throttle but is hard to make out.
Bet that link is what you're looking for.
EDIT (yet again): When you follow the exploded view, it appears to work some sort of check valve and probably allows extra fuel to enter the intake stream. I'd say Wing's got it. :idea:
April 09, 2012, 05:26:18 PM
« Reply #3 on: April 09, 2012, 05:26:18 PM »
I was thinking about the CV idea too.
Is this it?:  http://www.boats.net/parts/detail/yamaha/Y-66M-14368-01-00.html
April 09, 2012, 05:30:43 PM
« Reply #4 on: April 09, 2012, 05:30:43 PM »
Part #s match. :thumleft:
April 09, 2012, 06:52:51 PM
« Reply #5 on: April 09, 2012, 06:52:51 PM »
Accelerator pump
April 09, 2012, 08:42:00 PM
« Reply #6 on: April 09, 2012, 08:42:00 PM »
Quote from: "wingtime"
Yes it does,  I had to always run with the choke slightly engaged to keep it from stalling, hopefully this is the problem.
Thanks for the help everyone  :thumright:
