Author Topic: ignition switch sticking  (Read 336 times)
April 07, 2012, 08:10:34 PM
Read 336 times
plugger
« on: April 07, 2012, 08:10:34 PM »
Looking for some insight as how best to procede with replacement, it has what apears to be a lock nut holding it to the front of the key/throttle unit. Should i loosen and push it through & work from the under side of the console ? Or should i remove the four screws and tilt the whole key/throttle assembly forward and replace the leads  from topside.
205 Osprey
April 07, 2012, 10:02:35 PM
Re: ignition switch sticking
« Reply #1 on: April 07, 2012, 10:02:35 PM »
Quote from: "plugger"
205 Osprey
What I would do.  There should be enough service loop in the harness to allow you to back the key switch out and pull it down or up to deal with the leads on the back side...
April 08, 2012, 09:10:58 AM
« Reply #2 on: April 08, 2012, 09:10:58 AM »
Don't know if you've tried this, but before you take it out, give it a shot of WD-40, disconnect the battery, and work it back and forth a few times.  Often that will fix a sticky switch...   :wink:
April 09, 2012, 07:26:48 PM
plugger
« Reply #3 on: April 09, 2012, 07:26:48 PM »
Ok thanks
For peace of mind, i'll change it out !!
