Author Topic: Battery size  (Read 531 times)
April 07, 2012, 03:36:56 PM
Read 531 times
J Mac
Battery size
« on: April 07, 2012, 03:36:56 PM »
My battery was stolen from my 17.5 aquasport. I have a fishfinder and livewell. Do you think the battery below would be sufficient. The battery would need to be 11" by 7" to fit correctly. Batteries in acid group 27 and 31 are too big
John
Lead Acid Dual Purpose Battery
Item # : 204698
12 Volt,Type: Lead Acid,Group: 24
Amp Hours: 70, Reserve Capacity: 130, Cranking Amps: 685
Terminals: Post & Stud
Manufacturer: Sportsman
Model Number: DP24M
This product ships truck
April 07, 2012, 04:14:47 PM
Re: Battery size
« Reply #1 on: April 07, 2012, 04:14:47 PM »
Yes, it will be fine.  One thing you may want to consider is to carry a spare on board with you if you don't have room to mount a second batt permanently...
April 07, 2012, 11:21:31 PM
Treefish
    • http://www.youtube.com/watch?v=rMj9hRafqyQ
Re: Battery size
« Reply #2 on: April 07, 2012, 11:21:31 PM »
You'll be good with the 24. I've got a 24 in mine. I run a 1100gph livewell pump, a lowrance hds5, and a stereo with a 350 watt amp. I've been through an entire year fishing and into the second year and never had to charge my (walmart) battery. Fires right up.
April 07, 2012, 11:29:54 PM
Re: Battery size
« Reply #3 on: April 07, 2012, 11:29:54 PM »
I agree with the others, I have 2 24's on my boat and while camping out i run the fans, stereo, dvd you name it and always have enough left in that battery to start but like Bob said a spare is cheap insurance.
April 08, 2012, 03:51:38 AM
fmaster360
Re: Battery size
« Reply #4 on: April 08, 2012, 03:51:38 AM »
You getting it cheap online or something?
Carl
\'00 Osprey 205 w/ 200hp Ocean Pro
April 08, 2012, 07:25:31 AM
Re: Battery size
« Reply #5 on: April 08, 2012, 07:25:31 AM »
I've been having a rash of bad luck on my 24Ms from walmart - on the 3rd one in 2 years.  I do leave it on a charger when I'm not using it though.  I leave my 24Ms in the 230 on a charger also and am into the 3rd year on them.
April 08, 2012, 09:07:45 AM
Re: Battery size
« Reply #6 on: April 08, 2012, 09:07:45 AM »
I'm an AutoZone battery fan.  They may all come from the same plant, but I've had better luck with the AutoZone batteries than those from Wal-Mart.
April 08, 2012, 09:06:43 PM
Re: Battery size
« Reply #7 on: April 08, 2012, 09:06:43 PM »
I always got between 2-3 years out of Walmart batteries however the one in my work trailer is going on 6 years old (it was originally in my boat for 2 years) prior and it still works fine, it never gets charged until it's real low.
