Author Topic: Fuel Filter Selection  (Read 370 times)
April 06, 2012, 04:33:35 PM
Read 370 times
Pirate0408
« on: April 06, 2012, 04:33:35 PM »
I'm currently using a Sierra 90 GPH/10 micron filter at over 90% efficency water/fuel separator.  I'm thinking about switching out to a Racor, water/fuel separator with the clear bowl.  I've read here and there that Engine HP divided by 10 will give you an approx. flow rate of fuel required by the engine. (Or is this an approx. consumption per hour calculation?)  In my case, (2000 Model Johnson 200) this will equal approx. 20 Gallons/Hour.  I'd like to drop down to the Racor 60 GPH instead of using a 90 GPH given the space required for the 90 GPH Racor assembly, and in my case it seems to be overkill.  I've tried to find an accurate calculator, or some decent literature on the subject, but I'm coming up empty handed.
Aubrey B. Taylor, III
1979 22-2 Family Fisherman w/ 2000 200 HP Johnson
2008 176 Jones Brothers Bateau w/ 2008 50 HP Yamaha
April 06, 2012, 04:50:24 PM
Re: Fuel Filter Selection
« Reply #1 on: April 06, 2012, 04:50:24 PM »
Actually you'll be fine with the 30 GPH...
April 06, 2012, 05:00:19 PM
dburr
« Reply #2 on: April 06, 2012, 05:00:19 PM »
Look up a Racor 120R-RAC-01.. That should be 30gph with a clear bowl....
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
