222 CCP Rebuilds
1978 AquaSport 222CCP in Key West, FL.
Topic: 1978 AquaSport 222CCP in Key West, FL. (Read 5125 times)
April 05, 2012, 10:35:01 PM
Read 5125 times
SaltWaterSniper
April 05, 2012, 10:35:01 PM »
Hey Guys,
Capt. Jarvis here
http://www.SaltWaterSniper.com
Just wanted to share my project with other AquaSport Fans.
This picture is how I it bought and after an intense clean-up.
This is what it looks like now after 100's of hours of work and alot of money. 2 years later
Looking for a dive platform to complete the project.
April 06, 2012, 12:14:33 AM
ceejkay
Re: 1978 AquaSport 222CC rebuild in Key West, FL.
April 06, 2012, 12:14:33 AM »
nice transformation.. how deep of a build did you end up doing? or was it just a cosmetic build?
April 06, 2012, 01:33:36 PM
dirtwheelsfl
April 06, 2012, 01:33:36 PM »
Hows it run with the dusky drive?
April 06, 2012, 02:04:53 PM
SaltWaterSniper
April 06, 2012, 02:04:53 PM »
I didnt have to redo the floor, just mainly cosmetic, electric was all redone, I got a good deal on that E-tec. I found the T-Top on Craigslist it came off a 33' Avanti LOL but it measured up good just some welding to attach to the center console. Gel coat exterior, Awlgrip top side. It came with that motor bracket shown. I want to change it out for a swim platform. Things still to come a new touchscreen Garmin GPS probably 740s,& I have a baitwell I have to install on it.
Whats the dusky question I dont understand?
Compared to most other boats ive been on this 78' 222 is solid, takes waves amazingly. I go out in any weather,but a hurricane..only because It always works out like that on my days off. Ive taken it to the dry tortugas for the day, all the way out to almost Cuba..
rides strong.
April 06, 2012, 04:51:20 PM
dirtwheelsfl
April 06, 2012, 04:51:20 PM »
dusky drive is the bracket that dusky puts on their boats. looks just like the one youve got...
April 06, 2012, 09:53:43 PM
SaltWaterSniper
April 06, 2012, 09:53:43 PM »
probably a dusky drive. not sure thats the way i bought the boat. I would like to switch it out for a full length fiberglass Dive platform. to give it a slicker look.
April 07, 2012, 08:36:49 AM
Re: 1978 AquaSport 222CC in Key West, FL.
April 07, 2012, 08:36:49 AM »
Nice looking boat Capt.!
April 08, 2012, 02:08:51 PM
SaltWaterSniper
April 08, 2012, 02:08:51 PM »
any experts out there that can tell me the exact model of my hull, whether it is a 222CC, 222Cp,222DPV?
I know its a 1978 center console, but thats about it.
weight? any other info would help also.
Also correction to my previous post. I would like to get an Aluminum dive platform/ bracket to replace that Dusky Drive .
thanks.
Capt. Jarvis
SaltWaterSniper
April 08, 2012, 05:07:00 PM
April 08, 2012, 05:07:00 PM »
Center Console Professional (CCP)
Only thing we haven't seen is the inside. Does it have a large "coffin" in front of the console?
April 09, 2012, 11:43:37 AM
jdupree
Reply #9 on:
April 09, 2012, 11:43:37 AM »
Nice looking rig :!: As stated above you have the 22-2 CCP. The 1978 should have come standard with the coffin box. Look here and this will give you some further specs. This is off the 1980 brochure.
http://www.classicaquasport.com/gallery ... re&cat=572
John L. Dupree, III
AQABLA84E999
Member #257
April 10, 2012, 08:01:51 PM
kbn1942
Reply #10 on:
April 10, 2012, 08:01:51 PM »
Is the boat wet at all in a chop? And how does it run with the 250? Looks good though!
April 10, 2012, 08:21:09 PM
Global Moderator
Reply #11 on:
April 10, 2012, 08:21:09 PM »
Quote from: "kbn1942"
What do you consider a chop?
2'-3' beam seas or a quartering wind...
Oh yes, Aquas are wet.
April 21, 2012, 01:36:25 PM
SaltWaterSniper
Re: 1978 AquaSport 222CCP in Key West, FL.
Reply #12 on:
April 21, 2012, 01:36:25 PM »
The coffin outline was there. but i guess the original owner took it out.
Thanks for the info.
the 250 is a little heavy, but pushes her hard. compared to other 22' this boat takes waves pretty good, no complaints.
the inside still needs a little bit of cosmetic work but looks ok to go fish. Ill post some pictures of the inside this week.
THANK again
Capt. Jarvis
April 22, 2012, 02:24:57 PM
Mechanical Master
Reply #13 on:
April 22, 2012, 02:24:57 PM »
Looks like the original console, but I can't tell much from the pics. Your '78 would be essentially like my 1980 model. There were very few changes until the 1981 model year (which came out in late 1980). The biggest changes for 1981 were a smaller spashwell and a re-designed console. The boat was built to handle twin 140s, so the weight of a single 250 should not be a problem. My boat is more-or-less original if you want to see some pics and compare:
http://www.classicaquasport.com/gallery ... &protype=1
April 24, 2012, 01:34:12 AM
SaltWaterSniper
Reply #14 on:
April 24, 2012, 01:34:12 AM »
Your boat looks super clean on the inside,
Is that the Original door/hatch up front? Mine had a black plexiglass door which broke off.
Thanks for the help
222 CCP Rebuilds
