Author Topic: Solid transom, Wet transom...  (Read 853 times)
April 02, 2012, 09:08:53 AM
Read 853 times
CTsalt12
« on: April 02, 2012, 09:08:53 AM »
Ok so my '89 has what seems to me to be a solid transom.  I've had my 220 lb mechanic jump on the cavitation plate and no flex.  However, when taking out my salvage rings on the transom, the wood appears to be slightly damp.  Also, when taking out and reinstalling my bilge drain, when I drilled my lowest screw in, I definitely noticed some drips coming out of there.
I know it's kind of a "too late" situation, as I've already invested in the boat.  It seems very solid, no movement, but its damp in there.  Is there anything I can do to slow the rot?
Jimbo
1989 175 Osprey
April 02, 2012, 09:48:16 AM
Re: Solid transom, Wet transom...
« Reply #1 on: April 02, 2012, 09:48:16 AM »
It's already damp if you've got water dripping out.  Some folks will hook a vacuum up and try to suck as much water out as possible - it can't hurt, but I don't know if it really helps.  The wood boat restorers use acetone to help remove water/moisture.  You squirt the acetone into screw holes with a syringe and it will dry the wood out after a few applications.  Once the wood is dried, squirt Get-Rot into the holes to seal the wood.  It takes a couple days for the Get-Rot to fully penetrate and set.  Then make sure all holes/screws are fully sealed so water can't get back in.  As you can tell, this takes some time - some folks save it as an off-season project.
April 02, 2012, 04:23:02 PM
Curious
« Reply #2 on: April 02, 2012, 04:23:02 PM »
Read my 22 FF transom rebuild thread in this forum. You'll see a couple of comments I had regarding water dripping from screw holes near the base of the transom where I removed a transducer.  I also had a cracked and seperated top cap.  I was able to jump up and down on the outboard and had very minimal flex, but some.  I put a shop vac up against the dripping screw holes for like 10 minutes then checked the next day and they were dripping again.  When I dug out the plywood core (see thread) there were areas of smelly, black, soaked, rotten wood near any screw hole or scupper.  The rest of the plywood was solid and new looking but when I pushed a screwdriver into the solid areas water pushed up out of it so it was damp, just not rotten yet.  I'm also pretty sure some of the water was weeping into the transom from wet stringers, but I haven't gotten up the courage to drill into my stringers yet to see how wet they are.
Based on your post and my recent experience with my transom, (1978 22 Family Fisherman), I would say that yours has water intrusion around any screw holes or through hulls but might otherwise be solid.  The only other unknown is if your stringers are open cell foam and they are saturated, are they open to the transom and sharing some of the moisture there?  Some of the former employees here will know the answer to that.  I would seriously consider getting the boat inside, getting any screws and brass tubes removed, get it dried out and then re-seal everything with 5200 so you know you are starting fresh with everything sealed.  It could be solid but if it continues to get wet it will get heavy, wet and start to rot.
Dan
1996 Yamaha 200 SW Series
