Quote from: "RickK"I'm pretty sure that it was working on the other gauge though I'm going to climb back in there this morning. Any idea what color the TnT wires are in the bundle?The old tach had a connector that had 2 wires only. The new gauge has 4 wires in the connector.There is an issue using the new gauge with an older engine, I had the same problem on my 96 225 on the Chris craft when I put a new gauge in. There is nothing wrong with your trim sender, the harness as it is, is incompatible with the new gauge. I think there is a fix for it, but as Bob stated, I didn't worry about it.Here is a post on THT about it,http://www.thehulltruth.com/marine-elec ... new.html#b
Quote from: "flounderpounder225"Quote from: "RickK"I'm pretty sure that it was working on the other gauge though I'm going to climb back in there this morning. Any idea what color the TnT wires are in the bundle?The old tach had a connector that had 2 wires only. The new gauge has 4 wires in the connector.There is an issue using the new gauge with an older engine, I had the same problem on my 96 225 on the Chris craft when I put a new gauge in. There is nothing wrong with your trim sender, the harness as it is, is incompatible with the new gauge. I think there is a fix for it, but as Bob stated, I didn't worry about it.Here is a post on THT about it,http://www.thehulltruth.com/marine-elec ... new.html#bMy wife watched the gauge while I moved the TnT lever - still flashing on the top segment. :( The post on THT said that the engine the guy had, had a 3 wire trim sender. I'm not sure what I have but I know there is a setting on the gauge to switch it from 2 wire to 3 wire. It was factory set to 2 wire. The old gauge didn't have that switch. Maybe I'll try switching that. Ought to be fun getting to that switch now that it's installed - it's recessed deep into the back of the gauge under a rubber plug.
Like I said Rick. Want to know where the motor is? Turn around... 8)
You're not supposed to bleed when you're changing gauges <!-- s:roll: --><!-- s:roll: --> <!-- s:lol: --><!-- s:lol: --> The "new" one does look identical. Do you remember what the gray wire was used for? I don't remember if my old one had the gray on it.
I have not been able to find an original but as you know, the newer one (what you now have) is available. At this time though, I don't need to do that.
