Author Topic: Transducers  (Read 2016 times)
April 02, 2012, 01:01:37 PM
Reply #30
fmaster360
Re: Transducers
« Reply #30 on: April 02, 2012, 01:01:37 PM »
Does anyone know the angle of the transom on my boat? And on a side topic, can I use 5200 to fill in the old screw holes? They are pretty small, and I don't think they go all the way through...
Reading online, should I use the original holes, and then mount the new transducer on a piece of starboard?
Carl
\'00 Osprey 205 w/ 200hp Ocean Pro
April 02, 2012, 01:36:07 PM
Reply #31
TheKid
Re: Transducers
« Reply #31 on: April 02, 2012, 01:36:07 PM »
12 degree is the standard and what I have on a 222 FFV.
5200 could work in a pinch. I use epoxy to fill small holes. If you get the syringe type with a mixing tip you can shoot it in the hole. Then over fill slightly and use tape to hold it in. Then a light sand and done.
Since then, I bought a piece of starboard and made my own transom saver. I used that to cover all the holes on my 30 year old boat.
April 02, 2012, 01:56:21 PM
Reply #32
Re: Transducers
« Reply #32 on: April 02, 2012, 01:56:21 PM »
If you mean dead rise, that would be 19 degrees from what I have found. If in doubt, you could measure.
I'm fuzzy on the starboard mount thing :scratch:  so hopefully someone else will help with that.
April 02, 2012, 09:24:15 PM
Reply #33
Re: Transducers
« Reply #33 on: April 02, 2012, 09:24:15 PM »
Transom angle is not deadrise.
Here is a diagram and how to caclulate it.
http://www.rocketflap.com/transom_calc.php
April 02, 2012, 09:35:45 PM
Reply #34
Re: Transducers
« Reply #34 on: April 02, 2012, 09:35:45 PM »
Very interesting. I'll measure mine to satisfy my new found curiosity. I'm sure there must be something to gain by knowing that number.
Must be why they make outboards with adjustable trim.
Learn something new every day.
April 02, 2012, 10:32:17 PM
Reply #35
fmaster360
Re: Transducers
« Reply #35 on: April 02, 2012, 10:32:17 PM »
Thanks john!
Carl
April 02, 2012, 11:30:56 PM
Reply #36
Re: Transducers
« Reply #36 on: April 02, 2012, 11:30:56 PM »
Transom angles are typically around 13-14 degrees.  Use can also figure out transom angle and deadrise by using the Law of Sines, if anyone remembers back to their HS geometry days...
April 02, 2012, 11:36:29 PM
Reply #37
Re: Transducers
« Reply #37 on: April 02, 2012, 11:36:29 PM »
Dang Bob you beat me to it! I think we had the sine discussion about three years ago on here and if I remember you blew everybody away with your recollection and how most of us had forgotten how to use it!
April 03, 2012, 08:48:40 AM
Reply #38
Re: Transducers
« Reply #38 on: April 03, 2012, 08:48:40 AM »
I don't use Trig often but when I do.....
I prefer the Law of Tangents......
Stay ambiguous my friend. 8)
April 03, 2012, 04:42:42 PM
Reply #39
TheKid
Re: Transducers
« Reply #39 on: April 03, 2012, 04:42:42 PM »
Yes, tangent and specifically tan-inverse. Who needs a hypotenuse.
As for the need of knowing the transom angle, some transducers require the correct shim to install, that requires the angle.
Just installed a TM260 last week. Otherwise, I would not have a clue on the angle.
As for the starboard.....if you have a question let me know. It is easy to make.
April 03, 2012, 06:02:07 PM
Reply #40
Re: Transducers
« Reply #40 on: April 03, 2012, 06:02:07 PM »
Let's see if I can remember - SOHCAHTOA!   :cheers:
Sine = Opposite/Hypotenuse
Cosine = Adjacent/Hypotenuse
Tangent = Opposite/Adjacent
Man, that was in a back-of-the-head file folder...   :scratch:
April 03, 2012, 06:43:53 PM
Reply #41
Re: Transducers
« Reply #41 on: April 03, 2012, 06:43:53 PM »
Oscar (Opposite)
Had    (Hypotenuse)
A        (Adjacent)
Heap   (Hypotenuse)
Of       (Opposite)
Apples (Adjacent)
Sine
Cosine
Tangent
In that order
April 03, 2012, 06:44:09 PM
Reply #42
fmaster360
Re: Transducers
« Reply #42 on: April 03, 2012, 06:44:09 PM »
I got it installed, just drilled new holes. Came out nice. I stuffed some 5200 in the old holes with a syringe. Didn't think it would be nescessary to drill em out and put marine tex in this time since they weren't going to be tapped. I played with the 546s a bit, it's nice. The blue charts are cool, I guess. But not worth $240. Worth $40 I guess, if I get my $200 rebate back. Otherwise I'll be  :evil:
Carl
