I wonder if you can disable the wheel, and use the gps for speed.
Carl your going to like the 541 combo unit.
Keep in mind as you gain speed the sonar signal will degrade and the depth may become inaccurate.
One other related question for you all. I installed a transom mounted transducer last season and it worked great. However, at the end of a season on a mooring it was covered with barnacles. What type of anti-fouling treatment should I apply this season to prevent those buggers from hitching a ride??Thanks
