Author Topic: Touch Up painting Console / Interior  (Read 492 times)
March 16, 2012, 11:39:36 AM
Read 492 times
CTsalt12
« on: March 16, 2012, 11:39:36 AM »
Okay so one of the many previous owners of my vessel did something insanely idiotic and lazy.  He / she decided to put lacquer or some kind of protective coating on the teak pieces all over the boat, WITHOUT TAKING THEM OFF.  So as you can see, it got all over the hull, the console, and looks like :*:.
http://s1063.photobucket.com/albums/t50 ... G_0353.jpg
So I'm gonna sand / clean the :*: off, and I want to tough up these spots.
What should I use to touch up the paint on the console /  interior?  The areas aren't that large.  Will matching color spraypaint and a clear layer of that finishing spraypaint work?
Jimbo
1989 175 Osprey
March 16, 2012, 11:51:46 AM
Re: Touch Up painting Console / Interior
« Reply #1 on: March 16, 2012, 11:51:46 AM »
the best thing to do is to remove whatever that is and compound and wax,if you paint is is very hard to colormatch,try some 600 grit wet dry sandpaper to get the stuff off,maybe some acetone,depends what it is.will it scrape off with a razor?
work on a small section to see what works best.
March 16, 2012, 04:10:17 PM
« Reply #2 on: March 16, 2012, 04:10:17 PM »
As usual Pete is spot on.  Try to clean the stuff off the gel coat.  You can try a solvent of some type such as lacquer thinner or acetone.  If that doesn't work wet sand it in small sections until you see the white of the gel coat.  Then buff and wax it to a shine.
March 16, 2012, 11:26:10 PM
dburr
« Reply #3 on: March 16, 2012, 11:26:10 PM »
Razor to get the stuff off.. There should be little or no penetration to the gel coat then fine wet sand or buff out..  Unfortunately once stuff gets hard like that lacquer thinner or other solvents may not touch it..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 17, 2012, 11:37:51 PM
slippery73
« Reply #4 on: March 17, 2012, 11:37:51 PM »
Lacquer thinner should take off the residue, its most likely a spar varnish or a "teak oil".  "Teak oil" is just tung oil mixed with parts of thinner and varnish so that it cures faster.  About the only thing lacquer thinner wont remove is catalyzed finishes.
