Engines & engine woes
Engine hood paint & Decals
Topic: Engine hood paint & Decals (Read 527 times)
March 11, 2012, 11:02:03 PM
Read 527 times
March 11, 2012, 11:02:03 PM »
My Johnson engine hoods paint was faded and there were a bunch of pits in the paint and fiberglass. So I decided to paint it. Well that sounds easier than it was. First the decals had to come off. They were just olde enough that they would break when you tried to peel them off. I used a heat gun and a scrapper with good results. Then I had to clean off the adhesive with 3M adhesive cleaner. Once all the adhesive was off out came the DA. Unfortunatly the pits in the paint went down into the glass so sanding them out was not an option. I deiced to put a skim coat of bondo on to fill them up. I should have used some glaze since sanding the bondo down took longer than I expected. I sprayed on a couple of coats of white primer followed up with three coats of BRP white paint. For a rattle can the BRP touch up paint gives good results. I picked up a set of decals on ebay. The decals were pretty good but someone without experience putting on vinyl graphics would never get them on right. I had to cut a tweak the stripes to get them to come out right. Here's some porn shots:
Before:
Getting the graphics off:
close up of the pitting:
All the decals removed (the lights made stripes show up in my camera):
Painted with decals finished:
March 11, 2012, 11:50:48 PM
Unclebob
Re: Engine hood paint & Decals
March 11, 2012, 11:50:48 PM »
Wow. Spectacular job.
N.E. Florida
March 12, 2012, 12:00:17 AM
Rigging Master
March 12, 2012, 12:00:17 AM »
Well done, Bruce!! Looks excellent!
March 12, 2012, 01:18:12 AM
March 12, 2012, 01:18:12 AM »
Looks great Bruce, very well done, I learned my lesson years ago with these things after screwing up some decals, keep them wet.
March 12, 2012, 07:03:51 AM
Global Moderator
March 12, 2012, 07:03:51 AM »
Very nice indeed!
March 12, 2012, 09:03:21 AM
Purgatory
March 12, 2012, 09:03:21 AM »
Beautiful!!
March 12, 2012, 03:33:28 PM
March 12, 2012, 03:33:28 PM »
Thanks guy! It looks even better on the boat! Makes the whole back end of the boat look better!
