Aquasport Discussion
Cuddy access doors
Topic: Cuddy access doors (Read 426 times)
March 10, 2012, 12:45:30 PM
Read 426 times
cclovern
Cuddy access doors
March 10, 2012, 12:45:30 PM »
This may be a silly question but have any of you measured your cuddy doors ? I was going to make a set since mine are missing and found that there is a 2 inch difference in width of the opening top to bottom ? I am somewhat stumped do I have a structural problem ?
March 11, 2012, 06:42:48 AM
Re: Cuddy access doors
March 11, 2012, 06:42:48 AM »
What kind of boat?
My Explorer door is same top and bottom.
March 11, 2012, 07:48:15 AM
cclovern
March 11, 2012, 07:48:15 AM »
I have an 1979 Aquasport 22-2 FF
March 11, 2012, 08:54:10 AM
dburr
March 11, 2012, 08:54:10 AM »
A taper from top to bottom was the standard for companionway hatches for a "shipshape and yacht like" appearance, from the days of wooden boats and iron men.. It gives the hatch a non block like look when there are so many other curved surfaces around. That said, as long as the door trim is not loose that is the way it was built. Most folks would not notice it unless they put a tape on it. It is not something that you notice while looking at it because of all the other non straight lines in the boat but if it was dead square, it would just look wrong..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 11, 2012, 09:49:59 AM
cclovern
March 11, 2012, 09:49:59 AM »
Thanks for the information , guess I'll look for a set on ebay.
March 11, 2012, 10:03:39 AM
dburr
March 11, 2012, 10:03:39 AM »
If you google companion way doors there are a bunch of hits that show up... Happy hunting!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 11, 2012, 09:08:00 PM
bripley
March 11, 2012, 09:08:00 PM »
Early FF's like yours and mine had two panels that slid down from above into a track and locked when the hatch was closed down on top. Easy to duplicate and add tracks on each side.
Barry
1976 22 FF
Barry Ripley
1975 222 Family Fisherman with 2012 Mercury 150 4 stroke
March 13, 2012, 10:57:35 AM
cclovern
March 13, 2012, 10:57:35 AM »
bripley
Thanks for the information , I have a panel that slides on the top that would serve as a lock point and hinges for two doors but no doors.
Cuddy access doors
