Author Topic: Drain plug re-install  (Read 2648 times)
March 16, 2012, 11:07:45 AM
Reply #45
dburr
Re: Drain plug re-install
« Reply #45 on: March 16, 2012, 11:07:45 AM »
Cabinet scrapers can be found on Amazon, search Crown 376 cabinet scraper and that should produce a set for $16 that has a bunch of shapes.  If HD is going to have them it should be in hand tools but I have never looked there.. I got a set from Woodcraft.com, same as the Amazon set... You can also make them out of used up saw blades but it takes a little time.
If you search here for "new gel coat compound" there are a few threads that deal with how to get the best shine on the hull..
Good luck! :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
