Author Topic: fuel burn numbers  (Read 676 times)
February 28, 2012, 02:17:34 PM
Read 676 times
fuel burn numbers
« on: February 28, 2012, 02:17:34 PM »
ran the boat today to gather some data for my fuel burn. WOT i hit 5600 at 51 mph. might add a little more cup, wants to break loose when i run the jack plate high
14-1/2 x 19p OMC Renegade 4-blade
February 28, 2012, 02:24:02 PM
Re: fuel burn numbers
« Reply #1 on: February 28, 2012, 02:24:02 PM »
Impressive numbers.  25 gph at wot!
Now that I have a boat with a flowscan guage I was thinking of keeping a fuel log so I can keep track of my fuel usage etc.  Does anyone else do this? And if so do you have a sample log?
February 28, 2012, 02:27:27 PM
« Reply #2 on: February 28, 2012, 02:27:27 PM »
the main feature i like is i put in how many gallons i have in the tank, and set an alarm when it burns down to a certain amount, i have it currently set to go off when it gets down to a 1/4 tank
i want to run it head to head with my 23p to see what the fuel burn difference is.
kinda makes me want to repower with a new OB... but 10 grand does buy alot of fuel :drunken:
February 28, 2012, 02:49:37 PM
« Reply #3 on: February 28, 2012, 02:49:37 PM »
Hey, you're getting well over 2mpg at most speeds....lotta folks with new engines aren't getting any better :salut:
February 28, 2012, 04:03:19 PM
« Reply #4 on: February 28, 2012, 04:03:19 PM »
Aaron,
You're burn numbers seem high for a 200HP. You either got something going on in your fuel delivery system or effciency or you have more than 200 HP on your transom. That GPH supports 240HP and you should be going faster than 51 mph although I'm sure you are at max hull speed and adding HP won't make it go much faster. The OMC loopers were gas hogs; but typically not that bad... You are burning the same amount of fuel as twin 115's on my 22-2. Almost Identical gph and rpm @cruise and more on WOT. I can only get about 23 gph at WOT. As far as WOT rpm's you are golden at 5600. If she wants to ventilate, lower the jack plate.
February 28, 2012, 04:18:22 PM
« Reply #5 on: February 28, 2012, 04:18:22 PM »
she feels like she's bogging at WOT like from 5300-up theres no increase in power... when i had to replace my flywheel i think the timing adjustment screws got knocked out of placement by the flying magnets :shock: , one screw was bent. i was gonna check/adjust timing today but didnt have an extra set of hands...
also since the flywheel magnets blew apart and knocked stuff around, ive noticed more soot in and around the hub than usual... otherwise idle to say 4500 she runs the same as usual...
February 28, 2012, 08:56:00 PM
« Reply #6 on: February 28, 2012, 08:56:00 PM »
Agree with Fitz - those top end fuel numbers look way to high.  Is the motor trimmed out, or straight down?  Could be timing issue, but have you checked your jet sizes against the specs?
February 28, 2012, 09:24:58 PM
« Reply #7 on: February 28, 2012, 09:24:58 PM »
Aaron what kind of gauge are you using ?
February 28, 2012, 09:42:02 PM
« Reply #8 on: February 28, 2012, 09:42:02 PM »
I was thinking your WOT fuel burn was a tad high for a too.  I just came home from splashing "new" 245 Reel Crazy.   I was running 5600 at WOT and going just over 40 MPH and my fuel burn was about 23 or 24 GPH.  At 4500 RPM I was at 32 MPH and my fuel burn was 15-16 GPH.  I have no idea how to trim her out yet but that was with two people, 1/3 tank of fuel, full water tank and livewell.  It's early to tell but that works out to 2 MPG.   With a hard top in the wind?  I'm really happy!  :thumleft:
February 28, 2012, 09:49:49 PM
« Reply #9 on: February 28, 2012, 09:49:49 PM »
Quote from: "wingtime"
I would be too Bruce, good deal. Two mpg plus making that speed with a 2s is a happy number.
February 28, 2012, 10:10:54 PM
« Reply #10 on: February 28, 2012, 10:10:54 PM »
Here's what the old carbed Merc 200 Black Max gets on my 22-2 CCP:
February 28, 2012, 10:19:58 PM
« Reply #11 on: February 28, 2012, 10:19:58 PM »
40mph @ 23gph = 1.74 mpg... 32mph @ 15gph = 2.13  :scratch:
Quote from: "Circle Hooked"
its a navman fuel2100
Quote from: "GoneFission"
WOT was trimmed out, i have not checked the jets, as far as i know the carbs have not been apart but, im not sure. ill check into it more when im at work tomorrow... i do know she's due for new plugs and wires.
February 29, 2012, 12:55:16 AM
« Reply #12 on: February 29, 2012, 12:55:16 AM »
Quote from: "fitz73222"
Seems high to me too.  My 22-2 CCP with the '93 225 Oceanrunner could suck 23 gph but that was max.  (same fuel meter)
