Trailers
Cleaning up my I beams
Topic: Cleaning up my I beams (Read 1099 times)
February 20, 2012, 02:28:52 PM
Read 1099 times
Mechanical Master
February 20, 2012, 02:28:52 PM »
Hey Guys,
I'm working on my new used trailer and would like to brighten the Aluminum I beam. They are just a little gray and chaulky from sitting in storage. and I want to clean them up. I'm not interested in buffing and polishing a trailer, just looking for something I could spray on and hose or wipe off basiically just to break the haze and brighten it a little bit. I also want to be able to flush out my disc brakes effectively without crawling under the trailer and blasting them. I thought about rigging up some spray heads of some kind and make my own kit unless someone has a vendor suggestion for a good disc brake cleaning device.
Thanks,
Fitz
February 20, 2012, 02:40:12 PM
Re: Cleaning up my I beams
February 20, 2012, 02:40:12 PM »
Woody wax, I have not used it on an aluminum trailer but I have used it on aluminum with great results.
February 20, 2012, 02:44:38 PM
February 20, 2012, 02:44:38 PM »
I was told that swimming pool rust stain remover cleans aluminum pretty good but I have not tried it.
These folks used to sell a brake flush kit. It's just plastic hose, fittings, and a hose coupler. You can buy all the parts and make your own but the kit saves some running around.
http://www.sturdybuiltonline.com/
February 20, 2012, 02:53:59 PM
February 20, 2012, 02:53:59 PM »
There are some aluminum brighteners that pressure washing companies sell for use on aluminum tank trucks and dump trucks. They are acid based and etch the aluminum a bit but they do work. Another option is greased lightening. It has a mild acid in it that will brighten the aluminum a bit. spray it on... let it sit... maybe hit it with a scrub brush if it is really bad. Wand wash it off.
February 20, 2012, 06:59:06 PM
Purgatory
February 20, 2012, 06:59:06 PM »
A LIGHT acid....quickly hosed. let dry, then spray on Rupp Aluma-Guard to lubricate, protect and beautify.
(Yea I know...sounds like a make-up infomercial)
If you guys have never used it...the Rupp is a terrific product. PREVENTS corrosion and pitting.
February 27, 2012, 07:10:31 PM
Mechanical Master
February 27, 2012, 07:10:31 PM »
Try ammonia. Brush it on, scrub it with a hard-bristle brush, let it sit a while, and hose it off. Works pretty well as a de-oxidizer.
Trailers
