Author Topic: 1995 Fiberglass Fuel Tank  (Read 507 times)
February 20, 2012, 10:38:07 AM
Read 507 times
ReelEstate
    • http://www.Vero-Beach-Island-Homes.com
« on: February 20, 2012, 10:38:07 AM »
I am looking at 1995 175 Osprey with a fiberglass tank.  I have read reports that these tanks built in the 1980's deteriorated quickly when exposed to ethanol fuel and caused engine fouling and failures.  However, this boat is a 1995 model and does not seem to have any issues.  Did AS use a modified glass tank in the 90's to prevent failures?
February 20, 2012, 11:08:12 AM
Re: 1995 Fiberglass Fuel Tank
« Reply #1 on: February 20, 2012, 11:08:12 AM »
are you sure its fiberglass and not molded plastic?
February 20, 2012, 11:35:58 AM
ReelEstate
« Reply #2 on: February 20, 2012, 11:35:58 AM »
Maybe it is molded plastic.  I'll have to look again, but I thought I saw fibers in the glass.  Does anyone know what was the standard tank used in the mid 90's?
February 20, 2012, 11:45:15 AM
« Reply #3 on: February 20, 2012, 11:45:15 AM »
Most likely roto-molded polyethylene
February 20, 2012, 12:16:23 PM
« Reply #4 on: February 20, 2012, 12:16:23 PM »
I believe Poly tanks were standard on the smaller boats, including my 225, the 245's had aluminum tanks.
February 20, 2012, 12:59:05 PM
« Reply #5 on: February 20, 2012, 12:59:05 PM »
Scott and Scott are correct, roto-molded polyethylene, and, as Scott pointed out, used on all AS's up to including the 225.  The 245/250 and 275 got aluminum.
If I was building a boat today?  I'd go with roto-molded.  The problem is finding one that fit's the confines of the tank compartment, yet still allows maximum tankage...
February 20, 2012, 01:01:38 PM
ReelEstate
« Reply #6 on: February 20, 2012, 01:01:38 PM »
Thanks for the replies.
