Aquasport Discussion
Running shallow?
Topic: Running shallow? (Read 540 times)
February 16, 2012, 06:59:18 PM
Read 540 times
rob9
Running shallow?
February 16, 2012, 06:59:18 PM »
which model/year is best to rebuild into a flats/bay boat with a tower?
one that i can run shallow but still cut through 3 footer!
February 16, 2012, 07:18:32 PM
Re: Running shallow?
February 16, 2012, 07:18:32 PM »
The word you used that should be emphasized is "through" - the only AS boat that will push through a wave more than go over it and still fish skinny is the Flatback model.
February 17, 2012, 06:24:09 AM
Capt Matt
February 17, 2012, 06:24:09 AM »
If you want to run crazy shallow then get a flatback with a porta bracket
Capt Matt
www.captmattmitchell.com
Light tackle sportfishing
February 17, 2012, 07:30:21 AM
Mechanical Master
February 17, 2012, 07:30:21 AM »
If you want to run insane shallow, get a flatback and put a jet outboard on it.
February 17, 2012, 08:15:45 AM
Mechanical Master
February 17, 2012, 08:15:45 AM »
Quote from: "GoneFission"
The only problem would be you would have to fiberglass a keel from a Shamrock on her to be able to steer it in following sea! I bet running winding creeks in a flattie with a 200 jet at 30 mph would be a blast! The thing would look like an old Harley flatracker going around a turn!
Running shallow?
