Author Topic: 22 2 What Propeller ?  (Read 953 times)
March 19, 2006, 04:19:30 PM
Read 953 times
fpalmer
« on: March 19, 2006, 04:19:30 PM »
1977 22 2 Center Console, all orginal, currently repowering w/Yam 150 ox66 (saltwater series II) Any suggestions on correct propeller ?
March 20, 2006, 07:36:31 AM
« Reply #1 on: March 20, 2006, 07:36:31 AM »
What is your wide open throttle rpm with a normal load?  Prop should be pitched to give you approximately max factory listed rpm with your normal load.
March 23, 2006, 06:59:57 AM
fpalmer
propeller
« Reply #2 on: March 23, 2006, 06:59:57 AM »
just rigged motor almost ready to sea trial, do not know what prop to try first ? thinking 4 blade for lift, as i shallow water fish.
March 23, 2006, 09:34:39 AM
DEFIANT
« Reply #3 on: March 23, 2006, 09:34:39 AM »
If you call a Yamaha dealer they can get you in the ball park. If you buy from them they may let you test a prop to see if it is the correct one.
When I had an old Johnson the dealer assisted me as did the Suzuki dealer when I upgraded. You may have to pay a bit more with the dealer, but to get the right prop is well worth the extra cost!
March 23, 2006, 08:16:48 PM
Prop
« Reply #4 on: March 23, 2006, 08:16:48 PM »
If you want a guess, I would start with an 18 or 19 pitch.  If I wuz a bettin' man (which I'm not - I always lose!), I would bet on either a 19 or a 17.  But, as the sticker on the car says, "your results may be different."
Good luck!!
