Author Topic: 1972 22-2 trailer  (Read 822 times)
February 11, 2012, 04:02:03 PM
Read 822 times
clementsea
  • NorthEast
1972 22-2 trailer
« on: February 11, 2012, 04:02:03 PM »
Looking at buying a 1972 22-2... no trailer with boat.  Is there a general rule when it comes to trailer size vs hull length?  This will be my second boat, first one already had a trailer... I'm hoping to keep it on a single axle trailer for weight & maneuverability.  Will a single hold a 22-2?  Thanks!
1976 22-2
Cape Cod
February 11, 2012, 04:08:33 PM
Re: 1972 22-2 trailer
« Reply #1 on: February 11, 2012, 04:08:33 PM »
Length and weight are what you want to concern yourself with in regards to a trailer.  Single would probably work, but a double is the way to go.
February 11, 2012, 07:18:59 PM
« Reply #2 on: February 11, 2012, 07:18:59 PM »
A big single will work...but a tandem axle is preferred.
Especially a pull for any distance.
If one tire blows...at least you'll get to the next exit.
February 11, 2012, 10:29:13 PM
« Reply #3 on: February 11, 2012, 10:29:13 PM »
Just make sure the bunks are under the stringers. Tandem axle is the way to go, as has been said.
February 12, 2012, 04:42:26 PM
clementsea
  • NorthEast
« Reply #4 on: February 12, 2012, 04:42:26 PM »
Bunks under the stringers... I don't know the hull well enough to know from the outside where the stringers run...
1976 22-2
Cape Cod
