Author Topic: Horse Power options for a 1976 170  (Read 1486 times)
February 17, 2012, 06:27:17 PM
akbridge
Re: Horse Power options for a 1976 170
« Reply #15 on: February 17, 2012, 06:27:17 PM »
Quote from: "Fletch170"
I'm thinking of running nitrous.
BTW, anyone know what would be a good prop for the 17, running a 115 Two Stroke?
-Fletch
A 17 inch pitch three blade should do well. Are you going to run a backplate or use it for skiing?   If so you might drop down an inch and go to a four blade.  I think merc props fit that engine.  That opens your possibilities up.  Merc props are some of the best.
February 17, 2012, 08:45:57 PM
Fletch170
« Reply #16 on: February 17, 2012, 08:45:57 PM »
The only thing I'll be pulling behind the boat is a minnow bucket.
1981 2100 CC Hydra Sport
1976 170 (sold)
March 28, 2012, 02:37:51 PM
Fletch170
« Reply #17 on: March 28, 2012, 02:37:51 PM »
Since I'm not doing any skiing with this boat, is a 21" pitch,  13 3/4 " prop going to work? I want to get the most out of my top end. Will this bog the motor?
BTW, I have a 97 115 Yamaha 2 Stroke.
1976 170 (sold)
March 28, 2012, 07:03:32 PM
akbridge
« Reply #18 on: March 28, 2012, 07:03:32 PM »
Thats too big for your engine.  Your hole shot will be slow.  And your top will be poor with you engine always lugging.   I run a 14 inch pitch and have a mean hole shot and mild topend.   A higher pitch does not mean more speed.
March 29, 2012, 11:21:45 AM
kraw2
« Reply #19 on: March 29, 2012, 11:21:45 AM »
I changed my mind again....
After going thru amd repainting the Evinrude 70 hp. my friend wanted it really bad for his work barge.
He was in a bind and needed it right away to keep working.
Because of his lack of patients (sp) with working on outboards he traded me (2) 5Ohp, (2) 90hp, and a 115hp. All the motors are 1990's and above with the 115 being a 1995. The 115 has 150 psi all around. I will sell the others for parts if they are not worth the time to get right.
March 31, 2012, 02:32:00 PM
Fletch170
« Reply #20 on: March 31, 2012, 02:32:00 PM »
How about a 17 pitch, 13.2 diameter prop? Yamaha shows that the recommended prop is 17 pitch and 13 diameter....but I can't find a 13 inch diameter prop?
1976 170 (sold)
March 31, 2012, 06:26:43 PM
akbridge
« Reply #21 on: March 31, 2012, 06:26:43 PM »
That prop will be fine.  The pitch is more important than diameter.   A smaller diameter will allow a quicker rev up and can help with hole shot.  The pitch determines the boat speed relative to engine speed.  I like this website: http://www.rbbi.com/folders/prop/propcalc.htm most gear cases use 2.0:1 ratio, figure a max speed of 40 mph, 10% slip and engine speed of 5250 rpm.
March 31, 2012, 09:20:06 PM
Fletch170
« Reply #22 on: March 31, 2012, 09:20:06 PM »
I really thought I would get 45 mph out of her. Oh well, I guess I will be better off having an all around good prop.
1976 170 (sold)
April 01, 2012, 12:02:17 PM
jsakat1
« Reply #23 on: April 01, 2012, 12:02:17 PM »
I have a 130 on my 87 170, and the fastest I gotten is 46. I think the mounting on the motor has contributed to such a slow performance. But I redid the floor and transom, with no wood and I think it will be faster. The day that I put a 4-stroke. I was looking at a 115 yamaha, but weight wise is a lot. The 90 4-stroke looks like a better fit.
1987 170 Striper
April 01, 2012, 08:58:55 PM
Fletch170
« Reply #24 on: April 01, 2012, 08:58:55 PM »
I knew I wouldn't be building a speed machine, but I think the 115 yams 2 stroke is the perfect power for this boat.
1976 170 (sold)
April 01, 2012, 09:09:49 PM
Capt Matt
« Reply #25 on: April 01, 2012, 09:09:49 PM »
4 strokes are for barges and the retired lol
Capt matt
Light tackle sportfishing
