Author Topic: 72 22-2  (Read 737 times)
February 11, 2012, 03:19:49 PM
Read 737 times
clementsea
  • NorthEast
72 22-2
« on: February 11, 2012, 03:19:49 PM »
wondering how difficult it is to "tighten up" a bow rail on a 72 22-2... seller says that it's loose.  Is the rail thru-bolted thru the cap?  Can you get at the underside of where the rail is attached?  I'll have more questions on this one soon... thanks!!!
1976 22-2
Cape Cod
February 11, 2012, 03:50:47 PM
Re: 72 22-2
« Reply #1 on: February 11, 2012, 03:50:47 PM »
From the factory they were just screwed to the deck.  Over the years the holes waller out and the screws have nothng to grab.
The boat is 40+ years old, and if all original she is going to need some love.  Thru bolting is an option if not already done, but not the best fix.
February 11, 2012, 05:14:08 PM
clementsea
  • NorthEast
Re: 72 22-2
« Reply #2 on: February 11, 2012, 05:14:08 PM »
So... how would the best fix be done?
1976 22-2
Cape Cod
February 12, 2012, 08:25:22 PM
Capt Matt
Re: 72 22-2
« Reply #3 on: February 12, 2012, 08:25:22 PM »
remove the bow rail, grind out the gelcoat and glass where the mounting holes are, reglass, re gel coat, re drill and re mount the rail. better yet take it off for good and fill the holes
Capt Matt
Light tackle sportfishing
February 12, 2012, 09:15:07 PM
clementsea
  • NorthEast
Re: 72 22-2
« Reply #4 on: February 12, 2012, 09:15:07 PM »
OK, got it... I'll probably have to keep the rail for a while kussa the kids.  Probably find a way to tighten it up till I can do it for real.  Thanks for the info!
1976 22-2
Cape Cod
February 12, 2012, 09:49:55 PM
Spectre5922
Re: 72 22-2
« Reply #5 on: February 12, 2012, 09:49:55 PM »
DUCT TAPE FTW!    :cheers:
Seriously.....  I thought long and hard about whether to keep my bow rail or not and decided to ditch it.  It is a MUCH cleaner look.  If my kids can't follow directions and manage to stay in the boat, then they won't go out in it with me.  If you have very small kids, disregard my previous comment!   :mrgreen:
1976 Aquasport 19-6
Old 1982 Evinrude Sea King 140
February 12, 2012, 11:01:44 PM
Re: 72 22-2
« Reply #6 on: February 12, 2012, 11:01:44 PM »
Safety takes precedence over looks (and it should)...bed it down with 5200, then re-screw. Deal with pretty later.
February 13, 2012, 11:33:19 AM
clementsea
  • NorthEast
Re: 72 22-2
« Reply #7 on: February 13, 2012, 11:33:19 AM »
Gran,
Thanks... nothing like 5200 to keep things from falling off the hull!  I've seen folks mention marine tex to fill holes prior to re-screwing also.  The cap is a plywood sandwich right?  Probably good to get it watertight to prevent the cap from taking on water...
1976 22-2
Cape Cod
February 13, 2012, 04:07:43 PM
clementsea
  • NorthEast
Re: 72 22-2 bow rail
« Reply #8 on: February 13, 2012, 04:07:43 PM »
Wondering if the bow rail on a 19-1 is the same as a 22-2...
1976 22-2
Cape Cod
