Electrical
Courtesy/Cockpit lights
Topic: Courtesy/Cockpit lights (Read 1325 times)
February 08, 2012, 11:53:57 AM
Read 1325 times
Mulv80
February 08, 2012, 11:53:57 AM »
I want to replace my courtesy lights on my 99' 215 DC. Does anyone know what brand lights were OEM? I'm looking online and want to make sure my new lights arent too small for the existing cutout.
99\' Aquasport 215 DC, Johnson 200 Ocean Pro
February 08, 2012, 08:04:41 PM
Mulv80
Re: Courtesy/Cockpit lights
February 08, 2012, 08:04:41 PM »
Does anyone know how big the current cut out is for the stock Aquasport courtesy lights? This is the problem when your boat is 2 hours away.
February 08, 2012, 10:45:55 PM
February 08, 2012, 10:45:55 PM »
Try doing something like Pete did:
http://classicaquasport.com/smf/index.php?topic=8398.0
February 09, 2012, 12:46:15 AM
skyliner4444
February 09, 2012, 12:46:15 AM »
Not sure if the 1999 has the same. I have a 2003 215 DC and just replaced mine. My livewell had the same light too. They were the round Seachoice with the nut on the back. As I remember, mine had a mounting hole diameter of like 7/8" or 1" and were very difficult to find as most were 3/4" or less or did not list the mounting hole size at all. I ended up replacing my 3 courtesy lights with some nice oval blue leds that screwed in from the outside. Large enough to cover the hole and just used a little silicone around the edge to seal, and they look great. The big plus is the new lights are sealed LED's. I did finally find a Seachoice (also sealed led) in the right size for my livewell at my local marina's store. If you need a part# let me know as I may be over that way this weekend.
April 22, 2020, 09:03:46 PM
dbrook74
April 22, 2020, 09:03:46 PM »
Long shot on an old topic. Do you have the part numbers on the courtesy lights and how do you remove them?
I also have a 2003 215 DC
April 26, 2020, 01:08:36 PM
howesdivin
April 26, 2020, 01:08:36 PM »
I replaced my light bulbs in 2017 with LED light bulbs from Amazon. They have worked well for live well and courtesy lights. I did not change out the housings, just the bulb itself. I also ordered white ones and replaced running lights and anchor lights. 1999 245 Explorer.
YITAMOTOR 194 LED Blue 12v, 20 pack
1999 225 Explorer
July 19, 2021, 03:49:37 PM
itscaptainmjaqua
July 19, 2021, 03:49:37 PM »
Also need to change some bulbs on a 2003 215 Explorer. Is it easier to remove the rod holder panel in the cockpit, or can I remove the bulkhead behind the locker from in the cabin? My hands are just a bit too big to squeeze inside the rodholder holes.
Electrical
