Basically: Is there a problem with the original finish (which is gelcoat right?) bonding with the epoxy primer and then going back to a Poly topcoat?
Most Awlgrip topcoat systems are a polyester based polyurethane. After finish sanding the 545 primer with 400 grit, there should be no problem with adhesion. Follow their directions on the awlgrip website and you shouldn't have any problems.
Sent Awlgrip a question on their website. Thanks for the feedback everyone. Blue- Still 50-50 on the blue... your advice/experience with yours has me rethinking to a lighter color.
Slippery73 makes excellent points, although I would recommend that any paint job be waxed every six months. Especially if it is used frequently. Also, Awlgrip most certainly can be buffed. Before you do, make sure and call Awlgrip support and discuss buffing with them.Before buffing.......After buffing......
