Author Topic: Advise Needed  (Read 661 times)
January 31, 2012, 08:36:44 PM
Read 661 times
kraw2
Advise Needed
« on: January 31, 2012, 08:36:44 PM »
I want to bond some backing material to the inside sides of the original 170 center console. The backing material will be for attaching screws for wire managment, fuse box, terminal blocks, etc.
I was thinking about using 1/4" Starboard or other plastic material. Any ideas..?
Thank you
January 31, 2012, 09:06:08 PM
Fletch170
Re: Advise Needed
« Reply #1 on: January 31, 2012, 09:06:08 PM »
Hey! I did the same thing but used 3/4 Ply and glassed it in. 1/2 inch would have been enough!
Check out the link to my blog (in my signature). I think Starboard would be great, I just had some nice ply sitting around.
Have any pictures of your rig?
-Fletch
1981 2100 CC Hydra Sport
1976 170 (sold)
January 31, 2012, 09:10:41 PM
Re: Advise Needed
« Reply #2 on: January 31, 2012, 09:10:41 PM »
Kraw,
You can't bond starboard, nothing adheres to it.  I use 1/4" PVC board I get from HD, then bond it to the console sides (insides, of course!) with 3M Bondo Resin Jelly I get from Wally World.  Price just went up, about $13 a quart.
Trust me, this method works...
http://www.youtube.com/watch?v=315hAy_l ... ature=plcp
February 01, 2012, 11:01:05 AM
sealion2288
    • http://facebook.com/robbrown64
Re: Advise Needed
« Reply #3 on: February 01, 2012, 11:01:05 AM »
Kraw,
Thanks to Bob, I too have used this method. I used 3/4" PVC from Lowe's. The resin jelly bonds fast, even at 50 degrees, so you can get back to work quickly. It's soft enough that screws start easily with just a regular screwdriver, yet it has good compressive strenth. I've used the 3/4" PVC for backing on cleats, too.
February 01, 2012, 05:32:33 PM
kraw2
Re: Advise Needed
« Reply #4 on: February 01, 2012, 05:32:33 PM »
Thanks Guy's,
I found some at Home Depot. 5/16"x6"x8' PVC trim board. Basically I think it's soffit board. Will work great.
 :salut:
February 01, 2012, 09:27:05 PM
Re: Advise Needed
« Reply #5 on: February 01, 2012, 09:27:05 PM »
Quote from: "kraw2"
Thanks Guy's,
 :salut:
That's the stuff!
