Author Topic: Awlspar/teak question  (Read 710 times)
January 31, 2012, 02:15:51 PM
Read 710 times
Spectre5922
« on: January 31, 2012, 02:15:51 PM »
I have a few questions about the teak I'm restoring. I'm using Awlspar M3131 Classic finish on the teak on my boat. I have been told that I need 5-6 coats, hand-sanded between coats. My questions are, 1. Is there any time frame (keep in mind that I'm in 70 degrees in a Texas winter) that I need to wait before sanding after each coat, or just hit it when it feels dry?, and 2. What grit sandpaper would you use between coats? For my first pass before I started, I used 220 grit.
I'll send pics after the first coat has dried.
Thanks for any advice.
Brent
1976 Aquasport 19-6
Old 1982 Evinrude Sea King 140
January 31, 2012, 03:34:24 PM
Double Trouble
  • NorthEast
Re: Awlspar/teak question
« Reply #1 on: January 31, 2012, 03:34:24 PM »
Quote from: "Spectre5922"
Brent
I would look on the can or better yet on their site for coating time. As far as grit I would use 150 grit before first coat and 220 is fine between coats if you are sanding by hand sand with the grain, if you are using an orbital palm sander run the machine with the grain or you will leave swirl marks that wont show up until you put the finish on. I always sanded by hand between coats and not harder then needed to get out bumps and imperfections.
January 31, 2012, 04:05:01 PM
Spectre5922
« Reply #2 on: January 31, 2012, 04:05:01 PM »
Thanks for the reply. There are no instructions on the can except how to thin it if necessary. I am hand Samsung between coats (and before the first coat). All Samsung has been done with the grain. This is going to be a LONG process! I need to get some of those pyramid stands so I can coat it, flip it over and coat it again.
1976 Aquasport 19-6
January 31, 2012, 05:07:52 PM
Double Trouble
  • NorthEast
« Reply #3 on: January 31, 2012, 05:07:52 PM »
Here is what I found on the net.
APPLICATION INSTRUCTIONS
 Awlspar Classic Spar Varnish can be used to seal wood and build up a complete finishing system. Alternatively, Awlbrite Quik-Fil Clear J3901/J3902 is a clear, fast drying wood grain filler that can be used to seal the wood prior to finishing with Awlspar M3131 (4-6 coats). See the relevant product datasheets for details.
 After new wood has been sealed, or on previously coated surfaces, apply light, smooth, even coats (2-3 mils wet) of full bodied material. At temperatures above 75°F, 2 to 3 coats can be applied per day. If sanding is required, allow to cure 24 hours before sanding. Best results are achieved when surface is sanded smooth with 320 -400 grit paper after every 2 to 3 coats. If building M3131 as a stand alone coating, repeat this process until the grain is filled and covered, 7-10 coats may be needed. Exact number of coats needed will vary by applied film thickness, the amount of sanding and type of wood. For the traditionalists the Ultimate Brightwork System offers excellent performance longevity: Use Awlspar M3131 to seal and provide some color to the bare wood. Apply 2-3 smooth coats. Leave to dry for 72hrs minimum at constant temperature of 75°F/25°C. In colder temperatures leave up to 7-10 days before finishing with Awlbrite Clear Urethane (available in full gloss or semi gloss finish). See the application guide and/or your Awlgrip representative for further choice in systems.
January 31, 2012, 06:04:37 PM
Spectre5922
« Reply #4 on: January 31, 2012, 06:04:37 PM »
Thanks for the information . My Internet connection at work has been horrible today and I have not been able to get on their website . I really appreciate it !
1976 Aquasport 19-6
January 31, 2012, 06:45:50 PM
« Reply #5 on: January 31, 2012, 06:45:50 PM »
Wow,
That's a lot of work. You must really want a glass top finish. Definitely not my style for teak but fully understood.
January 31, 2012, 07:53:08 PM
Spectre5922
« Reply #6 on: January 31, 2012, 07:53:08 PM »
I'm not going to the extreme of glass smooth. I just want it well protected and.not rough looking. That Awlspar Classic sure is beautiful. It has a very warm tone to it!
1976 Aquasport 19-6
