Author Topic: possible purchase 95' 200CC many questions  (Read 957 times)
January 28, 2012, 08:22:05 PM
Read 957 times
CaptDag
« on: January 28, 2012, 08:22:05 PM »
possible deal for a 95' 200CC with 112 Evinrude.
Good points and bad for this model? things I should look for duing inspection. I'm thankful for any advice or opinions .
 http://s1146.photobucket.com/albums/o531/captdag/
January 28, 2012, 09:56:54 PM
Re: possible purchase 90's 200CC need advice
« Reply #1 on: January 28, 2012, 09:56:54 PM »
First off, welcome aboard!!!
When you get a chance post in this thread so we can learn a little about you.
http://classicaquasport.com/phpbb3/view ... f=1&t=6358
To post pics you can follow this thread. You will need a photobucket account to do this.
viewtopic.php?f=6&t=2847
Things to look for are discussed in this thread.
I would type this out again but this thread is only about a week old. If we didn't cover something that concerns you just ask, you WILL find this site has absolutely the most supportive members of any site on the web. We also try to have a good time doing it as well!!!
viewtopic.php?f=1&t=8349
January 28, 2012, 10:13:16 PM
« Reply #2 on: January 28, 2012, 10:13:16 PM »
Welcome aboard Captdag  :salut:   Lew is correct, you will find everything you wanted to know about Aquasports, and then some... Good luck with your prospective new rig.  :thumright:
January 28, 2012, 10:16:42 PM
« Reply #3 on: January 28, 2012, 10:16:42 PM »
Welcome Aboard :cheers:
January 28, 2012, 10:22:04 PM
« Reply #4 on: January 28, 2012, 10:22:04 PM »
good luck with your new rig! :salut:
January 29, 2012, 08:08:17 AM
CaptDag
Re: possible purchase 90's 200CC (pictures added) need advice
« Reply #5 on: January 29, 2012, 08:08:17 AM »
OK , have pictures available now. Thanks Lewis for your help.
more info from owner. boat is a 95 model with a 112 evinrude and seems to be in very good condition. owner is interested in possible trade for my smaller aluminum rig. what i need from the experts:
how much is she worth assuming everything in good mechanically?
does this year have wood transoms?
anyone have or had the 112 engine?
fuel capacity? fuel tank aluminum or poly?
Thanks again ,Guys
January 29, 2012, 08:17:47 AM
« Reply #6 on: January 29, 2012, 08:17:47 AM »
That year boat should have a poured transom.
January 29, 2012, 08:41:56 AM
« Reply #7 on: January 29, 2012, 08:41:56 AM »
Nice looking rig, you can tell it has been taken care of.  The 112 SPCL like all of the smaller V4's is a very reliable and pretty efficient engine.  The motor probably did not come with VRO, I think the SPL designation on OMC motors was for different horsepower and emissions rating for international sales, that 112 should be a very basic and easy engine to keep maintained.   For pricing.... That is very speculative, being based somewhat on your geographical area and the boat market?  Personally I break the rig down by trailer, engine and boat to try and get a better feel for where the price should be.  So, just assuming all items are in above average condition?
Trailer.... $800
Engine....$1500
Boat.....$2500 to $3000 depending on accessories and stuff coming with the sale.
So probably somewhere in the mid 5K range, again, please remember this is just my very basic way of getting to a starting point in my head, and as many have said before, a used boat is only worth what someone will pay for it.  And make sure you have the boat and engine checked over completely, wiring, pumps, accessories, engine compression and any fuel issues.  Plan a long sea trial, run that rig around for at least an hour, WOT, low speed trolling, mid range etc...  Good luck
January 29, 2012, 11:17:16 AM
« Reply #8 on: January 29, 2012, 11:17:16 AM »
May be hard to read but second from top right is your boat.
January 29, 2012, 01:28:14 PM
T Race
Re: possible purchase 95' 200CC many questions
« Reply #9 on: January 29, 2012, 01:28:14 PM »
Welcome Captdag,
  Good luck with your prospective boat purchase... it has "YOU" written all over it !
T Race
1999 Aquasport 215 Explorer, IO, Hardtop
2006 Ford F-150 SCab, 4WD
January 29, 2012, 06:17:25 PM
« Reply #10 on: January 29, 2012, 06:17:25 PM »
Quote from: "CaptDag"
Thanks again ,Guys
looks identical to my boat (minus t-top) when i bought it!!!
mine has a wood transom, so yours will too.
mine originally had the 112, great motor, very reliable, not bad on gas, very basic, cruised 25 mph and 37-39 mph wide open. wanted to go faster so i swapped out to a 200hp.
fuel capacity seems to be different between years, ive pumped my tank bone dry and have only been able to put 47 gallons plus a gallon of 2-cycle so im guessing 50 gallons would be closer
mine has a poly tank.
heres a before and after of my '96
January 29, 2012, 08:23:06 PM
« Reply #11 on: January 29, 2012, 08:23:06 PM »
That's amazing - are you sure you have wood in the whole transom?  My '93 was made in the same place as your '96 and my transom is poured up to the top where the engine mounts.  From there, on the sides, it is wood though.  I found that out because where the corner lifting eyes are, rotted out on one side and needed to be replaced on one side but the transom was solid as a rock (it is a rock).
January 30, 2012, 08:04:01 AM
« Reply #12 on: January 30, 2012, 08:04:01 AM »
yes my transom is wood...
January 30, 2012, 08:12:09 PM
« Reply #13 on: January 30, 2012, 08:12:09 PM »
Rick, Aaron,
175s (170s as well, before the "size" change) and 200s were built on the same line, sort of a "lesser" tier AS than say, the 225s and 245s at that time (your 230 as well, Rick)...
That being said, some builders will do things a certain way up to a particular model.  Usually a "price point" sort of thing.  Get above that model, and things are done differently...
Case in point.  At Proline, 23 and under got poly fuel tanks.  Above that?  Aluminum.  Price point, that's all it was...
