Or run two pickups...
Dual port Shur-flo 800 LW pump feeding a Shur-flo Pro Blaster 3.5 washdown pump...keeps the costs down...
You can always build a seachest if you have the room. Pumps run cooler, no priming issues, you can use standard bilge pumps.... almost all of the big boat builders use them. They seem like the way to go if you have the room.
Scotty, don't forget a strainer after that seacock. With all that chicken that's going to be consumed, you're going to need top performance out of that washdown pump buddy. http://www.sherwoodpumps.com/en-us/Prod ... Strainers/
Slippery, I don't think I've ever seen a seachest in any boat smaller than a 50...
Quote from: "seabob4"Slippery, I don't think I've ever seen a seachest in any boat smaller than a 50... I don't think I've ever seen a seachest. Pls explain.
