Author Topic: Boat Wiring...  (Read 2241 times)
January 24, 2012, 09:48:43 PM
Read 2241 times
Boat Wiring...
« on: January 24, 2012, 09:48:43 PM »
There has been much said about wiring on boats, about premature failure of equipment on boats, about corroded terminals, switches, breakers, fuse holders, you name it, on boats.  All of which lead to one sort of failure or another, some minor (your courtesy lights quit), some major (you've sprang a small leak, and the bilge pump no longer works).  But failures non the less.
A lot of these failures are blamed on the equipment.  But one must remember.  The equipment gets it's power from the leads that feed it.  If the leads that feed the equipment are black with corrosion, if the switch terminals, fuse blocks, and breaker terminals are green with corrosion, large amounts of resistance are introduced into the circuit that makes the equipment work that much harder to produce, and induces premature failure due to the conditions under which the equipment has to work.
And the corrosion that is evident in any harness does not stop at the plugs or butt splices that connect that equipment to the leads that feed it.  The corrosion is in the leads off the lights, off the pumps, it's in the motor windings, it's in every part of that equipment that has any contact with electricity.
I do re-wires and re-rigs, installs for a living.  I see this every day, day in, day out, on all different brands of boats.  They live in a nasty environment.  Can an owner stop the inevitability of corrosion from happening?  No.  But with regular maintenance, the application of anti-corrosion sprays and compounds, can great extend the life of a boat, electrically.  But, inevitably, there is going to come a time when equipment starts failing, and simply replacing that equipment is just going to buy an owner a little bit of time before that equipment has to be replaced again.
I'm writing this because I am getting some inquiries as to whether I can do work for some owners, just to get this working, to get that working...of course I can. But when I get under a console, and the whole fuse block is corroded, when the breaker terminals are as green as the scum on a pond, what's the point?  So, I got an owners nav lgts working this week, what happens when his washdown pump craps out next month?  And the bilge float switch the month after that?
The way I look at it, any smaller boat from an average builder that is around 10 years old needs a complete rewiring.  That is especially true when the boat lives very near to shore, especially in the south along the Gulf coast.
This is not written in an effort to increase my business load, I am doing fine, and enjoy doing what I do.  I am fortunate.  But over the past several days, due to some emails, due to some reading, I just thought I would put this out there for those to ponder, and hopefully to look into their boats and do a few more things that can make their boat live longer, more useful lives, and to give their owners the enjoyment that they bought her for in the first place for...
Thank, jawz...
January 24, 2012, 10:52:01 PM
Re: Boat Wiring...
« Reply #1 on: January 24, 2012, 10:52:01 PM »
:thumright:
January 24, 2012, 11:17:50 PM
Re: Boat Wiring...
« Reply #2 on: January 24, 2012, 11:17:50 PM »
Excellent post Bob!
And I paid particular attention to the resistance advice. Especially true on the VHF feed. Nowadays, VHF's will internally shut down when below a constant 12.5V
January 24, 2012, 11:41:22 PM
icemanbryan
Re: Boat Wiring...
« Reply #3 on: January 24, 2012, 11:41:22 PM »
Yes, well said.
January 24, 2012, 11:47:51 PM
Re: Boat Wiring...
« Reply #4 on: January 24, 2012, 11:47:51 PM »
Excellent post Bob!
Scott, and others,
Resistance, in the form of corrosion or inferior wiring creates 2 things.  First, voltage drop.  Even though a particular appliance is designed to operate at, say, 14.5V-9.5VDC, it's really happy at the upper end.  At the lower end, it's working hard, not nearly as efficient as it was designed to be...at the proper voltage.  Second, resistance creates heat.  Heat is bad.  First, it takes energy to create heat, energy that should be used to power that appliance.  Second, heat, uncontrolled, can cause fires.  We hear about this quite often when boats catch on fire at marinas, not fuel related...
January 24, 2012, 11:52:03 PM
T Race
Re: Boat Wiring...
« Reply #5 on: January 24, 2012, 11:52:03 PM »
Good post, Bob.
A thought, seeing how's I just bought this 12 Volt Bible.
Maybe you could write a small book and publish it.  For various reasons - lack of time, lack of finances, lack of confidence, lack of
technical guidance - the average boat owner is, at times, going to continue to to look for that 60 or 70 percent solution ("Hey, can
ya just get my steaming lights working"), short of the optimal 100% solution, which is having the boat rewired.
What do you think about writing a book that:
A) teaches us all the maintenance tricks we can employ to make the boat last as long as it can, and
B) how we can trouble-shoot the 10 or 15 most common electrical problems.
Write and publish it yourself, you'll have a tidy income that if nothing else will give you beer money for those delicious AND nutritious
Natty Lites !!
T Race
1999 Aquasport 215 Explorer, IO, Hardtop
2006 Ford F-150 SCab, 4WD
January 25, 2012, 12:07:18 AM
Re: Boat Wiring...
« Reply #6 on: January 25, 2012, 12:07:18 AM »
Great post Bob, and like T said do the book, in this economy alot of guys try to tackle this stuff on their own and it would be a big help.  :salut:
And don't forget about SEA BOBS SHIP YARD, the next youtube hit.
January 25, 2012, 12:16:25 AM
Re: Boat Wiring...
« Reply #7 on: January 25, 2012, 12:16:25 AM »
Hey...I concur with T on the book. You should do it. And additionally, should be pretty easy... you are an accomplished writer.
And also agree with Scott regarding a reality show. Son's of Guns, Gold Rush,  Swamp Loggers (hey, I know that guy) and many more. You just need to be "discovered".
Lewis...Lewis...
 :thumright:
January 25, 2012, 12:32:48 AM
Re: Boat Wiring...
« Reply #8 on: January 25, 2012, 12:32:48 AM »
Trace, you are one funny, and insightful man!!!
A little story when I was at Proline.  When Suzuki first came out with their Digital (SMIS) gauges, basically Lowrance LMF-400s or 200s (4" and 2"), it was part of my job that once a boat was rigged and ready for the engines to be run, I had to go out and configure the gauges. as the guys in the plant just weren't familiar with the stuff to do it on their own.  Don't blame them, it's a high dollar option, so not exactly a day to day thing.  So I wrote a "Programming guide", did it in Excel, complete with screen shots, pics of hardware, the whole nine yards.  Printed out a copy for all the motor installers to have.
Well, I showed it to our Suzuki guy, my good friend Jon.  He took it with him...a couple weeks later, I get an email from his boss out your way (American Suzuki is based in the LA area), asking if I could put it on disk and send it to him.
A long story short.  Couple months later, Suzuki comes out with a technical bulletin...with my damn programming guide in it!!!  In fact, my co-engineer pointed it out to me!  Said, hey, Bob, remember that guide you wrote?  And showed me the Zuke bulletin...
And that is a true story.  They owe me royalties!!!  But I did it so that one, the guys on the floor could feel empowered, knowing they could do it on their own, and two, it freed me up to do things more akin to my job...
So, on to your premise...to write a book, no, maybe a booklet, about basic wiring techniques and basic wiring troubleshooting.  With pics and diagrams.  Take some time, take some putting together...and I'd probably have to throw a vid in there or two...
An e-book?
January 25, 2012, 12:44:36 AM
Re: Boat Wiring...
« Reply #9 on: January 25, 2012, 12:44:36 AM »
Sorry Scott, Scott, took me a bit to think and write my last post...
Damn it boys, I may just have to tackle this little project...
January 25, 2012, 01:10:50 AM
Re: Boat Wiring...
« Reply #10 on: January 25, 2012, 01:10:50 AM »
:cheers:  :cheers:  :cheers:  if you don't we will bug you till you do  :D
January 25, 2012, 06:25:11 AM
Curious
Re: Boat Wiring...
« Reply #11 on: January 25, 2012, 06:25:11 AM »
While on the subject, what do you guys recommend as a "Boat wiring for dummies" book?  I am looking for an easy to read guide that will help me understand the basics, down to what color wires should be used for what?  Don't worry, I'm going to have a professional do the bullk of the wiring but I need a basic understanding.  Until Seabob's book comes out......
Dan
1978 22 Family Fisherman
1996 Yamaha 200 SW Series
January 25, 2012, 08:41:26 AM
Re: Boat Wiring...
« Reply #12 on: January 25, 2012, 08:41:26 AM »
Quote from: "Curious"
Curious,
Actually, the book Trace picked up, "The 12 Volt Bible for Boats" is probably the best read out there.  It's written very well, and pretty much goes on the premise that the reader is not entirely familiar with the concepts of 12V electricity and how it works.
The easiest way to describe the 12V concept is to imagine a circle, with a battery at the top of the circle, a device (light, pump, GPS unit, whatever) at the bottom of the circle.  12V flows to the device on the positive side of the circle, and flows back to the battery from the device on the negative side of the circle.  Interrupt any portion of the circle and you have no power.  That interruption is most commonly seen in the form of a switch.  When the switch is off, the contacts inside the switch do not make contact with each other, so the circuit is interrupted (open).  Turn the switch on, and the contacts touch each other, the interruption is gone (the circuit is closed), and viola, you have power.
The biggest problem facing boat owners is that when you turn on the switch, you have no power.  Unless the device has simply failed (burnt out bulb, burnt up pump motor, etc.), the fact that you have no power means that there is an interruption in the circuit somewhere else, an interruption that wasn't intended (a switch is intended).  So obviously, the trouble-shooting key is to find that unintended interruption and repair it.
There, easy isn't it?
January 25, 2012, 10:53:01 AM
icemanbryan
Re: Boat Wiring...
« Reply #13 on: January 25, 2012, 10:53:01 AM »
OH, I know about heat and wiring!
Yes, an ebook would be great Bob.
Excellent post Bob!
Scott, and others,
January 25, 2012, 12:06:34 PM
Re: Boat Wiring...
« Reply #14 on: January 25, 2012, 12:06:34 PM »
Bryan, you certainly do, my friend!  That was a fun ordeal, wasn't it!!! :shock:  :shock:
