Author Topic: New battery  (Read 949 times)
January 15, 2012, 12:46:52 PM
Read 949 times
J Mac
New battery
« on: January 15, 2012, 12:46:52 PM »
I need to replace the battery in my 17.5' aqua sport. I trailer the boat so really don't use a bilge. Electronics on boat are a fish finder and live well. What type of battery would be best. Any specific make do you think would be best
John
January 15, 2012, 01:09:40 PM
Re: New battery
« Reply #1 on: January 15, 2012, 01:09:40 PM »
First, you SHOULD have a bilge pump aboard, along with a float wired hot to the batt.  I have a couple used Attwood Tsunami 1200s if your interested...
A good group 27 dual-purpose batt should do the trick.  They have higher reserve capacity than group 24s.  I'd stick with lead acid to keep costs down as opposed to AGMs...
JMHO...
January 16, 2012, 05:36:43 PM
J Mac
Re: New battery
« Reply #2 on: January 16, 2012, 05:36:43 PM »
Thanks sea bob. So many different batteries these days not sure what was best
January 16, 2012, 06:49:00 PM
Re: New battery
« Reply #3 on: January 16, 2012, 06:49:00 PM »
Quote from: "J Mac"
You could spend days on THT reading all the BS about what's the best...some of those guys don't mind dropping upwards of $250 for an Optima Blue Top...
The rest of us?  We live in the real world... :wink:  :wink:
January 16, 2012, 08:08:46 PM
Re: New battery
« Reply #4 on: January 16, 2012, 08:08:46 PM »
I have two of these on board.
http://www.westmarine.com/webapp/wcs/st ... sNum=50544
Ridiculously priced now but....
One is 9 years (2002) the other not quite 5 (2007). In those days they ran about $180 (group 27).
I'd say I got my money's worth. Still crankin' my 91 200, after service on the old CCP. Replaced them both in 2002 and had one fail in 07.
I'm not close to livin' in the real world. Haven't for years.
January 16, 2012, 11:28:01 PM
Re: New battery
« Reply #5 on: January 16, 2012, 11:28:01 PM »
Quote from: "Capt. Bob"
I suppose we all fit into that category...
January 17, 2012, 12:10:45 AM
Re: New battery
« Reply #6 on: January 17, 2012, 12:10:45 AM »
Capt Bob I've been using the Worst Marine, SeaVolt AGM batts for two years without a hicup, used your link and looked them up to see what they cost now  :shock:  :shock:
January 17, 2012, 09:06:51 AM
Skoot
Re: New battery
« Reply #7 on: January 17, 2012, 09:06:51 AM »
You would be fine with any size Dual Purpose lead-acid battery. Autozone carries a Duralast grp27 Marine for around $100.  Seabob knows is chit, so go with the group 27 and you'll have no worries.
1975 19-6 - 90hp Tohatsu
January 17, 2012, 09:14:57 AM
Re: New battery
« Reply #8 on: January 17, 2012, 09:14:57 AM »
I used a Nautilus deep-cycle in my old full size Blazer, lasted for 7 years here in the FL heat.  Still going strong when I broke a terminal...
January 17, 2012, 11:25:17 AM
Re: New battery
« Reply #9 on: January 17, 2012, 11:25:17 AM »
John,
The two key points made so eloquently here are....
1. Get a battery you are comfortable with price wise, mounting position and charge-ability. Mount it where it won't get beat all to hell, is easy to access for maintenance (if required) keep the connections clean, tight and properly sized (for minimum voltage drop) and above all, charge it correctly (and keep it charged) based on type.
2. That "what battery to use" threads are like any other opinion threads (think oil or gas additives).
Everyone's got one.
January 17, 2012, 12:02:06 PM
Re: New battery
« Reply #10 on: January 17, 2012, 12:02:06 PM »
John,
Everyone's got one.
Or what motors, for that matter (Etec VS Yam VS Merc VS Zuke)...I pay ZERO attention to any of that!
January 17, 2012, 01:04:49 PM
Re: New battery
« Reply #11 on: January 17, 2012, 01:04:49 PM »
John,
Everyone's got one.
Didn't we have a pic awhile back of a boat with all four :D
January 17, 2012, 01:09:39 PM
Re: New battery
« Reply #12 on: January 17, 2012, 01:09:39 PM »
Scott, pretty sure it was 3...Yam, Etec, and Merc...see if I can find it...
Yep, here you go...
January 17, 2012, 01:13:24 PM
Re: New battery
« Reply #13 on: January 17, 2012, 01:13:24 PM »
i seem to remember a Honda too  :scratch:
That pick looks like tenth street ramp.
January 17, 2012, 01:33:42 PM
Re: New battery
« Reply #14 on: January 17, 2012, 01:33:42 PM »
OK John,
There you have it.
Get ya 1 lead-acid, 1 AGM and a gel.
Ought to be just about right for the 17.5
Bob's already got a wiring schematic done. May need a little tweeking but.....
Finished product will look similar to this (different batteries of course).
See, that wasn't so hard. :roll:
