Hey fletch170, Just got through looking at your blog and noticed how you cut your floor out and the way you had your stringers capped 8) .Are you going to glass the cap to the stringer? With the floor laying right on the cap of the stringers you will be fine
...Just tab the floor up the liner wall and it should be good to go..I would put something adhesive between the floor and the stringer cap(just being me). The main reason I used tabbing cloth to tab mine in was that it made it easier to get it attached that way..For me trying to run the 17 oz biaxial over the floor and up the wall would not have been as easy....the 17 oz doesn't want to make turns and bends to easy so it was easier to tab and cut the floor cloth to go to the edge of liner..Your coming along nicely, once the floor is in and glassed it starts to pick up the pace, I just wished I had some time now to work on mine, it will be next week before I even get a chance to even look at it for longer than 10 minutes, but that's life
