Author Topic: Transom Bait Boxes  (Read 3395 times)
July 02, 2012, 07:30:32 PM
Group W Bench
Re: Transom Bait Boxes
« Reply #15 on: July 02, 2012, 07:30:32 PM »
The dimensions of the tops were reduced for a substantially tighter fit around the box and less overhang.
Quote from: "kraw2"
I can't tell by the pictures but are the tops designed so the box can fit tighter to the transom than the original?
July 07, 2012, 03:14:04 PM
kraw2
« Reply #16 on: July 07, 2012, 03:14:04 PM »
Where can I get the adjustable flow riser shown in the pictures?
July 07, 2012, 05:33:59 PM
kraw2
« Reply #17 on: July 07, 2012, 05:33:59 PM »
Where can I purchase the "Johnson Mayfair adjustable flow spray heads" shown in the pictures..??
July 08, 2012, 10:10:54 AM
« Reply #18 on: July 08, 2012, 10:10:54 AM »
Evidently Eugene has not seen your question. It might be better to call him direct at Shipoke. I am sure he can tell you the best place to get them!
http://www.shipokeboats.com/
A side note, are you going to be out at the Blue Angels show? We will be down with Flounderpounder and a lot of my Atlanta friends that day and would love to meet up! A mini Aquasport gathering!
July 12, 2012, 07:24:44 PM
kraw2
« Reply #19 on: July 12, 2012, 07:24:44 PM »
I found the adjustable flow risers online. I watch the Blue Angles from my dock. They fly right over the house every year in the same flight pattern. Actually is get's kinda old after the 3 days of practise before the show.
PS.
They are called areator heads and you can get them in different lenghts. If you use a 1/2" high speed pick up you can easily use a 1/2" FIP x Socket PVC adapter to screw on the ends of the 1/2" male threads on the pick up. Glue on a short piece of 1/2" PVC, a ball valve, then a 1/2" PVC riser and cap the end. Cut slots in the PVC and your done.
Or a 1/2" threaded PVC ball valve screwed to the 1/2" high speed pick up. You would have to thread the valve on the male ends of the pick up before mounting the pick up to the box.
