Author Topic: Binnacle Mount Control Needed  (Read 730 times)
January 04, 2012, 07:05:06 PM
Read 730 times
kraw2
« on: January 04, 2012, 07:05:06 PM »
I need to know which binnacle control will work with a 1980 70 hp Evinrude. Can the newer ones be used? If anyone knows the correct one please let me know..!! It will be for an Aquasport 170 top mount. If anyone has one let me know..!!
January 04, 2012, 08:32:11 PM
Capn Mark
Re: Binnacle Mount Control Needed
« Reply #1 on: January 04, 2012, 08:32:11 PM »
I have several side mounts that will work with that motor if your needs change.......
January 05, 2012, 06:39:29 PM
kraw2
« Reply #2 on: January 05, 2012, 06:39:29 PM »
No Thank You,
I need a binnacle mount. With the boat's not being here right now I can't figure out which one will work. Most of the ones I see say they are for 1996 and above. I'm sure there's a way for them to work. Has anyone tried this??
January 05, 2012, 11:45:57 PM
Group W Bench
« Reply #3 on: January 05, 2012, 11:45:57 PM »
The most affordable option would probably be the Teleflex MN dual function, single lever control (314302-111). They are the black plastic ones with tilt/trim buttons on both sides of the lever. They work well and are only $135.00 new. The only drawback with them is that you have to closely follow the instructions provided as it relates to setting up the correct pin positions for OMC. They ship in the reverse pin configuration from what you will need.
Alternatively, you can use a new BRP single lever binnacle that are around $300. They are nice units, and you can order with integral key switch if you do not already have a hole for the key switch cut in your console.
January 05, 2012, 11:52:11 PM
« Reply #4 on: January 05, 2012, 11:52:11 PM »
I used one of the Telex controls that I bought on E-bay.  works good.  The set up is a little confusing but not hard.
