Author Topic: Anti-Corrosion coating  (Read 519 times)
January 04, 2012, 10:56:32 AM
Read 519 times
« on: January 04, 2012, 10:56:32 AM »
This is the coating I used on my tank to seal it against moisture and humidity.  Condensation on the deck plates when I opened it yesterday just beads up when it drips on the surface. This is a really neat product for interior use only.
http://dominionsureseal.com/productsdet ... 3&catid=28
January 04, 2012, 01:32:25 PM
Re: Anti-Corrosion coating
« Reply #1 on: January 04, 2012, 01:32:25 PM »
Sounds like it is very similar to Acf-50 or Boeshield used to protect aircraft.  Good find
January 04, 2012, 03:39:12 PM
kraw2
« Reply #2 on: January 04, 2012, 03:39:12 PM »
It seems this product is the same as Corrosion X heavy Duty. It comes in the green can and is very thick.
January 04, 2012, 11:31:56 PM
« Reply #3 on: January 04, 2012, 11:31:56 PM »
Have researched the Amber Anti-Corrosion.
Lew's new product, rather than thick...is thin. Wax-based. Light coating that permeates the aluminum substrate. Designed to adhere to fresh aluminum.
The good news....anti-corrosion. Aluminum in a salt water environment corrodes on its own. Quickly.
Look no farther than the legs of a T-top. Particularly at the weld joints.
