Author Topic: Teak under Center Console  (Read 949 times)
January 03, 2012, 10:58:40 PM
Read 949 times
kraw2
« on: January 03, 2012, 10:58:40 PM »
What do most of you use to replace the teak wood that is used under the center console of the smaller boats like the 170 I am working on. The teak can still be used with some restoration but there may be a better product to use now.
Thank you
January 04, 2012, 07:20:12 AM
Re: Teak under Center Console
« Reply #1 on: January 04, 2012, 07:20:12 AM »
Quote from: "kraw2"
Thank you
Kraw
Regular white Starboard, or if you want some more style, they make this stuff now.  Plasteak http://www.plasteak.com/  No maintenance.
January 04, 2012, 05:24:36 PM
« Reply #2 on: January 04, 2012, 05:24:36 PM »
Starboard would work great, although I would prefer the color almond to white.
January 04, 2012, 08:26:13 PM
« Reply #3 on: January 04, 2012, 08:26:13 PM »
When I redid my floor I made the trim out of 5/8" plywood with 45 degree edges, covered the wood in resin, stuck it on the new floor and glassed over it. Next I gelcoated and non-skidded (word?) the whole floor.  Then I mounted the console back on top of it.  VERY solid and no maintenance.  When I do my floor over again I will do the same.
June 06, 2012, 01:23:07 AM
« Reply #4 on: June 06, 2012, 01:23:07 AM »
I used "trex" decking material from Home Depot. Its composite and rot proof and easy to work with. I got the reddish color which looks really close to teak. worked well for me.
Check out page 2
viewtopic.php?f=2&t=3858&start=15
June 06, 2012, 11:07:41 AM
Fletch170
« Reply #5 on: June 06, 2012, 11:07:41 AM »
I threw mine away.
Gluing and screwing that badboy right to the deck.
1981 2100 CC Hydra Sport
1976 170 (sold)
