Author Topic: Steering Helm, Control Box and Rub Rail Replacement  (Read 759 times)
December 28, 2011, 01:06:35 PM
Read 759 times
kraw2
« on: December 28, 2011, 01:06:35 PM »
What steering helm replacement is most widely used on a 1976 170..? Teleflex No Feedback..?
I will also need a new binnacle mount control box for a 1980 70hp Evinrude. Will the newer ones work. Which one do I need..?
Also the rub rail..?
I have the original green rub rail that could be restored but the color will not work with the new hull color.
December 28, 2011, 07:51:06 PM
akbridge
Re: Steering Helm, Control Box and Rub Rail Replacement
« Reply #1 on: December 28, 2011, 07:51:06 PM »
Go hyd. on your steering.  I use a baystar system.  Its affordable and sized right for our boats.  Search on ebay for a Taco rubrail kit.  I went with black on black.  You might be able to find a binnacle on ebay as well or at a used marine store.
December 28, 2011, 08:07:52 PM
« Reply #2 on: December 28, 2011, 08:07:52 PM »
i also used the black on black taco kit, price was right and it looks good, simple to install
let me know if you want any specific pics...  :thumleft:
i want to say omc uses the same cables from 79-up so the newer style should work(im not 100% on this)...
like ak said, go with hydraulic. its worth the extra cost...
 :salut:
December 28, 2011, 08:52:24 PM
« Reply #3 on: December 28, 2011, 08:52:24 PM »
Quote from: "Aswaff400"
I wonder if that's where the Type 479 nomenclature came from? :?  :wink:
December 28, 2011, 09:25:47 PM
kraw2
« Reply #4 on: December 28, 2011, 09:25:47 PM »
Doesn't the rub rail need to flat on the back? Do you remember which model # you used?
Thank you
December 28, 2011, 10:12:56 PM
akbridge
« Reply #5 on: December 28, 2011, 10:12:56 PM »
I think this is what I used.  It has held up well.  The only difference is I used the black insert.
Taco Flexible Vinyl Rub Rail Kit - 1 1/4" H x 15/16" W x 50' L Black
Taco Rub Rail Flex Vinyl Kit 50 Black with White Insert V11-3447BWK50-2 flexible vinyl rub rail is easy to bend and provides a soft, cushioning effect against normal bumps from pilings and docks. Available in continuous coil for one piece instalation without seams. Tight radius bending can be made with no heating. « less
December 29, 2011, 02:24:00 PM
kraw2
« Reply #6 on: December 29, 2011, 02:24:00 PM »
Thank you for the response. I'm assuming that the small protrusion on the back will sqeeze tight when installing. The deck to hull joint is flat.
December 29, 2011, 04:54:08 PM
kraw2
« Reply #7 on: December 29, 2011, 04:54:08 PM »
The original steering cable measures 10'2" on the black part only. The numbers cannot be read. What lenght is normally used on a Aquasport 170..??
