Author Topic: 1972 19-6 Starting the rebuild!  (Read 933 times)
December 25, 2011, 03:31:38 PM
Read 933 times
South Bay Digger
« on: December 25, 2011, 03:31:38 PM »
Picked this boat up a month ago,have been looking for about a yr.Was wanting a 22-2 but I think this boat will work out well, here's the plan-  Removed old deck + casting platform.Removed stringer system (they were shot) foam was in pretty good shape though. Removed liner. Previous owner filled in transom w/ no cap, will be adding a 12" cap w/ a nice crown. Building a new stringer/rib system (planning on plywood box beams glassed over w/ biax). Spraying new foam wherever I can. I know the weight issue w/ the box beams, but I always overbuild, would rather be seaworthy then light + lively. Building up entire hull w/ extra glass. Raising up new deck a few inches, eliminating casting deck. Building under-deck watertight compartments. Will have two 2" scuppers in transom. Planning on a bracket w/ somewhere's around 140hp. Let me know your opinon's. For now its back to grinding down the old glass.
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/389835_10150984469810023_870515022_21666546_1647596276_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/386565_10150984467095023_870515022_21666541_578704727_n.jpg
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/391054_10150984622300023_870515022_21666784_852373442_n.jpg
December 25, 2011, 07:04:34 PM
Re: 1972 19-6 Starting the rebuild!
« Reply #1 on: December 25, 2011, 07:04:34 PM »
Hull looks in good shape from what we can see.
So the PO "poured" the transom?
December 25, 2011, 08:33:52 PM
South Bay Digger
« Reply #2 on: December 25, 2011, 08:33:52 PM »
Hey Rick-  No I think he filled the cut out w/ plywood + glassed both sides, actually did a pretty good job but didn't finish top to well. Was thinking of laminating another pc. of plywood to inside of transom, glassing the whole thing, then adding a 12" cap w/ a nice crown. Hope to do that soon, will post pics as I go.
December 26, 2011, 08:07:37 AM
« Reply #3 on: December 26, 2011, 08:07:37 AM »
South Bay, welcome aboard!  Good luck with the project.
December 26, 2011, 05:21:28 PM
South Bay Digger
« Reply #4 on: December 26, 2011, 05:21:28 PM »
The back cap looks great, that's what I'm shooting for. How do you like your Armstrong bracket? How heavy are they?
December 26, 2011, 09:17:06 PM
« Reply #5 on: December 26, 2011, 09:17:06 PM »
Quote from: "South Bay Digger"
Thanks!  I love the Armstrong bracket.  Can't remember what it weighs, installed it over ten years ago. If I had to guess, I'd say 80 lbs. or less.
December 27, 2011, 04:02:35 AM
« Reply #6 on: December 27, 2011, 04:02:35 AM »
Quote from: "Blue Agave"
I really like the real fiberglass hatch. You resisted the low cost plastic option. How do you handle the water drainage from the recessed lip or does it just drain into the bilge? This is exactly what I want to do with mine when the rebuild time comes. No plastic hatches!
December 27, 2011, 06:23:28 AM
« Reply #7 on: December 27, 2011, 06:23:28 AM »
The hatch does not have a drip rail. Any water that does hit that area would drain into the bilge. Has never been a problem, the only time there is water back there is when I'm done catching bait and I clean it up with a 5 gallon bucket.
December 27, 2011, 10:42:45 PM
Capt Matt
« Reply #8 on: December 27, 2011, 10:42:45 PM »
Fitz you are so right about plastic hatches, they simply do not last when used on a deck and stepped on.
I built all my hatches. They have drain channels, the back two are hooked together and drain right out of the transom. the front two are hooked together and drain out the side by the original drain.
Capt Matt
Light tackle sportfishing
