May have been a pop bottle. I guess I will never know though. Oh, I will be having many many days out on the water until then. I am that crazy person each winter breaking the ice around the shoreline at the boat ramp, so I can launch the boat. Its usually just me & the birds out there in the winter.I like working on boats in the winter time because all the boat dealers, prop shops, etc are begging for my business up here.I am going out again Friday and Christmas Eve. And December 26th as well. I have to make the most of my time off. Haha.-Ben
Where the rigging exits the side of the box going to the engines...is they're anything more attractive to use other than those collapsible rubber boots? Thanks!
A transom cabinet hides it well lolHow about running two rigging tubes against the inside of the stringers? then use the flex tube to hide everything from the deck to the motor.The twin motor rigging will take some thought to keep it all clean. Does it all need to come out of one side?Capt matt
Well, Scott, I certainly understand your want to keep the port side clean and "unencumbered". So another alternative is to tab a couple of 3" pipes on the outboard side of the starboard stringer, one for the boats harness and the starboard engine rigging, the other for the port engine rigging. Assuming your going to go with hydraulic steering and a tie bar, run the steering hoses in the port side pipe to reduce clutter If you're going to have the batts in the console, keep in mind, even with little 75s on the back end, you'll still want 2GA batt cables running aft to the motors. Each one of those little buggers is about 1/2" in diameter...
