Author Topic: tank cover -screws in to secure?  (Read 983 times)
December 15, 2011, 08:46:04 AM
Read 983 times
HIFLUTIN
« on: December 15, 2011, 08:46:04 AM »
Gettin ready to put my 170 back togther.
On the gas tank cover does everyone put screws in to secure or can get by with silicone/5200?
Hate to put holes in a new cover that we fabbed up?
December 15, 2011, 09:01:28 AM
Blue Agave
Re: tank cover -screws in to secure?
« Reply #1 on: December 15, 2011, 09:01:28 AM »
I put screws in mine after fabing it, made mine out of nidacore. I counter sank the screws, tens years and no problem. Also, don't use 5200!  Use some type of UV resistant silicone.
1975 19-6
3.0 EFI Mercury 150 4S
December 15, 2011, 09:12:08 AM
« Reply #2 on: December 15, 2011, 09:12:08 AM »
When I did my cover I reused the screws and they seem to help secure it down even more. I also overdrilled the holes and filled with thickened resin. I followed Skoot's lead and put a bead of plumbers putty down then dropped the hatch in, then the screws. I used clear marine silicone on the gap because if I ever need to get back in there it will be easier to remove. I would not recommend 5200 as you will tear the glass up if you try to remove the cover.
December 15, 2011, 09:22:15 AM
« Reply #3 on: December 15, 2011, 09:22:15 AM »
I used screws on mine.  5200 on the screws and marine silicone to seal it up.   As already mentioned  if you use 5200 getting back in there will be a bear.
December 15, 2011, 10:36:49 AM
« Reply #4 on: December 15, 2011, 10:36:49 AM »
5200 is not that hard to get out of a tank seam - been there and done that.  Utility knife will cut it.  But 5200 will yellow with sunlight, so 4000UV is probably a better choice.
December 15, 2011, 10:57:32 AM
« Reply #5 on: December 15, 2011, 10:57:32 AM »
Quote from: "GoneFission"
Agreed. It's what I used when I replaced the WAC tank last year. It seems to clean up better and return to its original white color very easily.
December 15, 2011, 11:41:28 AM
« Reply #6 on: December 15, 2011, 11:41:28 AM »
I was going to mention that 5200 yellowing was the second reason I didn't use it.  The white marine silicone I used stays nice and clean.  I figured if it starts to look funky I can easily peel it out and reseal it.
December 15, 2011, 05:03:06 PM
c master
« Reply #7 on: December 15, 2011, 05:03:06 PM »
I have clear silicone around the cover...it's been there for 5 years.  Looks like newly applied and almost invisible.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
December 15, 2011, 06:38:11 PM
« Reply #8 on: December 15, 2011, 06:38:11 PM »
I have seen some that use black silicone,looks cool and no mildew to worry about  :salut:
