tank cover -screws in to secure?
Topic: tank cover -screws in to secure? (Read 782 times)
December 15, 2011, 08:46:04 AM
Read 782 times
HIFLUTIN
December 15, 2011, 08:46:04 AM »
Gettin ready to put my 170 back togther.
On the gas tank cover does everyone put screws in to secure or can get by with silicone/5200?
Hate to put holes in a new cover that we fabbed up?
December 15, 2011, 09:01:28 AM
Re: tank cover -screws in to secure?
December 15, 2011, 09:01:28 AM »
I put screws in mine after fabing it, made mine out of nidacore. I counter sank the screws, tens years and no problem. Also, don't use 5200! Use some type of UV resistant silicone.
December 15, 2011, 09:12:08 AM
December 15, 2011, 09:12:08 AM »
When I did my cover I reused the screws and they seem to help secure it down even more. I also overdrilled the holes and filled with thickened resin. I followed Skoot's lead and put a bead of plumbers putty down then dropped the hatch in, then the screws. I used clear marine silicone on the gap because if I ever need to get back in there it will be easier to remove. I would not recommend 5200 as you will tear the glass up if you try to remove the cover.
December 15, 2011, 09:22:15 AM
December 15, 2011, 09:22:15 AM »
I used screws on mine. 5200 on the screws and marine silicone to seal it up. As already mentioned if you use 5200 getting back in there will be a bear.
December 15, 2011, 10:36:49 AM
Mechanical Master
December 15, 2011, 10:36:49 AM »
5200 is not that hard to get out of a tank seam - been there and done that. Utility knife will cut it. But 5200 will yellow with sunlight, so 4000UV is probably a better choice.
December 15, 2011, 10:57:32 AM
Global Moderator
December 15, 2011, 10:57:32 AM »
Quote from: "GoneFission"
Agreed. It's what I used when I replaced the WAC tank last year. It seems to clean up better and return to its original white color very easily.
December 15, 2011, 11:41:28 AM
December 15, 2011, 11:41:28 AM »
I was going to mention that 5200 yellowing was the second reason I didn't use it. The white marine silicone I used stays nice and clean. I figured if it starts to look funky I can easily peel it out and reseal it.
December 15, 2011, 05:03:06 PM
c master
December 15, 2011, 05:03:06 PM »
I have clear silicone around the cover...it's been there for 5 years. Looks like newly applied and almost invisible.
C Master
1975 Aquasport 170
file:///C:/Users/cliff.haehl/AppData/Local/Temp/IMG_0135.jpg
December 15, 2011, 06:38:11 PM
December 15, 2011, 06:38:11 PM »
I have seen some that use black silicone,looks cool and no mildew to worry about
2003 Osprey 225
