196 Rebuilds
82 aquasport osprey 19.6 rebuild
Topic: 82 aquasport osprey 19.6 rebuild (Read 15941 times)
February 23, 2012, 07:15:15 AM
Reply #45
gman 82 aquasport
Re: 82 aquasport osprey 19.6 rebuild
Reply #45 on:
February 23, 2012, 07:15:15 AM »
Thanks, it has been a eye opener for sure, but I find it sort of fun, it seems that the days I only have 2-3 hours to get on it , not much happens, but this week I've had all day long, Monday-Wednesday and will have most of today too..then back to the FD.
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 23, 2012, 11:43:30 AM
Reply #46
florida196
Reply #46 on:
February 23, 2012, 11:43:30 AM »
wow u sure do make it look easy thanks for all the pics will deffinatly help when i get started on mine.
February 23, 2012, 02:38:53 PM
Reply #47
gman 82 aquasport
Reply #47 on:
February 23, 2012, 02:38:53 PM »
hey florida196, might look easy, but some of it is and some not,mostly messy.I have already thrown out 2 pairs of pants from having resin all over them, stuff seems to jump on me, left one pair to dry in the garage and you could stand them up almost
The biggest thing I had going was I had already replaced the front section of floor last April so I could change the fuel lines and there was a soft spot in front, got that done and a soft spot shows up late summer in the rear so I decided to just rplace the entire floor redo the stringers and new foam..Biggest thing to make it easier was I took about a week after the floor was out and drew up what I wanted and where, made a bunch of measurements before I took the first thing off the boat. So I know exactly where I wanted things to be, got a bigger tank and moved it forward some, made my storage box under the floor, and made the front sort of like a bowrider( for the mrs)Still it hasn't totally pi$$ed me off yet! You will get there, just don't get an a gaint hurry, lucky for me I work 24 hour shifts so I have at least 3-4 days a week to get to work on it if nothing else is up. :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 23, 2012, 03:13:01 PM
Reply #48
florida196
Reply #48 on:
February 23, 2012, 03:13:01 PM »
ya the fire department gig youn cant beat that schedule thats what i went to school for but the hiring in the state of florida has come to a hault it seems like.
February 24, 2012, 07:43:14 AM
Reply #49
gman 82 aquasport
Reply #49 on:
February 24, 2012, 07:43:14 AM »
Yeah, I've got almost 25 years in now
Planning for my retirement from the department at the end of 2013, then headed for Carteret County, try to find something down there to get into...If you want PM me and I'll send you my # and your welcome to ask any ? about my boat and rebuild.... :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 28, 2012, 09:56:54 PM
Reply #50
gman 82 aquasport
Reply #50 on:
February 28, 2012, 09:56:54 PM »
OK, last 2 days were semi productive, got the last layer of glass on hull bottom outside of stringers
put everything loose in storage box
Poured my foam after glueing pipes together with the control cables in them, this is starboard /stern, left area by drains open
The pipes exit starboard rear, wires for lights will exit pipe in gunnel
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 28, 2012, 10:10:12 PM
Reply #51
gman 82 aquasport
Reply #51 on:
February 28, 2012, 10:10:12 PM »
The pipes with cables already in them, and wires to pull harness and lines thru in them as well
Shot from the stern of foam and storage box
Storage box with 1 coat primer, 2 coats paint
The bilge area with same # coats of paint
Going to be cutting and fitting the floor on Thursday, will cut all 3 pieces then glass the bottom and install...Probably won't get to glass the topside till Monday/Tuesday next week, got a lot of holes to cut for access and lines. :pirat:
Have decided that when I paint the new parts I'm going to repaint all the white on the liner/cap at the same time, going to try and spray it :)
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 28, 2012, 10:33:48 PM
Reply #52
Purgatory
Reply #52 on:
February 28, 2012, 10:33:48 PM »
Hey lookin' good!
If may make a suggestion...when you replace the treated chocks with cypress/starboard etc...since the tank is poly...place a bit of 3/16th's neoprene between the chocks as a chafe guard to the tank....running, beating, vibration, etc.
Great work!
Looking forward to seeing her in person
February 29, 2012, 08:06:58 AM
Reply #53
gman 82 aquasport
Reply #53 on:
February 29, 2012, 08:06:58 AM »
It's got a 1/4 in layer of foam between them now, do you think I need more?
Replaced treated with reg wood, if it rots up that high I have bigger problems! Also put a little foam in the corner areas of tank, maybe 4 in round area(softball size) to keep tank steady, the foam does flex a little. :pirat: Tank has 1 1/2 to 2 on all sides..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 29, 2012, 09:32:18 AM
Reply #54
Purgatory
Reply #54 on:
February 29, 2012, 09:32:18 AM »
Missed that
You're good!
February 29, 2012, 01:54:41 PM
Reply #55
gman 82 aquasport
Reply #55 on:
February 29, 2012, 01:54:41 PM »
Cool..Now for a question about the floor.
....I had planned on just butting the panels(panels will be glassed on bottom already) together with PB and then glassing the first layer opposite of the ply seams(seams port to starboard- glass bow to stern) then 2nd layer port-starboard...will this hold well enough? Trying not to overthink this thing
, but want it to last. Any input is appreciated :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 29, 2012, 08:57:46 PM
Reply #56
dirtwheelsfl
Reply #56 on:
February 29, 2012, 08:57:46 PM »
You need to put butt blocks under the wood seams. With the glass on top just run it fore and aft. Youll only end up with the overlap down the middle rather than the middle and a few going across the deck.
February 29, 2012, 09:25:14 PM
Reply #57
gman 82 aquasport
Reply #57 on:
February 29, 2012, 09:25:14 PM »
Thanks dirtwheelsfl, I can only put the blocks in the center as the foam pour is to the floor level...I plan on lying my 17oz cloth fore and aft then a layer of 6oz cloth side to side as a top layer, was thinking about 2 layers 17oz but it seems that people think thats a little much...plus the 2 layers of tabbing to the liner, 4in and 8 in.. :)
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 29, 2012, 09:29:03 PM
Reply #58
dirtwheelsfl
Reply #58 on:
February 29, 2012, 09:29:03 PM »
Sounds like a plan!
If you havent gotten the cloth yet, go with 10oz. Its easier to work with...
February 29, 2012, 10:21:57 PM
Reply #59
gman 82 aquasport
Reply #59 on:
February 29, 2012, 10:21:57 PM »
Already have it, 20 yrds 17 oz 50 in wide....10 yrds 6 oz 50 in wide..I've already used the 17 oz on the bottom and walls of the parts I've already put in so I've gotten used to dealing with the thickness :) Got all my cloth and resins and micro stuff and wood flour back in Jan. :pirat:
Also gran, looked back thru your post on your boat a while ago, she will be so sweet,
know you can't wait to get her on the water :)
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
196 Rebuilds
