Author Topic: 82 aquasport osprey 19.6 rebuild  (Read 16019 times)
March 18, 2013, 12:29:27 AM
Reply #135
gman 82 aquasport
Re: 82 aquasport osprey 19.6 rebuild
« Reply #135 on: March 18, 2013, 12:29:27 AM »
More pics of pulpit
side view before I cut the rails
a closer view
mostly finished , had a little problem bending the existing rail so it would line up and had to put some heat on it..
I filled my new piece to be bent with sand and wet the sand thinking this would keep me from kinking the pipe..WRONG..got about 2/3's way bent and it kinked, finished the bend and put it on and made a pattern and I will get someone with a mandrel bender to bend me a new piece.
Before I put the rail on I stood my 235 lb self on the pupit to see if it would hold me and well it didn't break so I was a happy camper :cheers:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 18, 2013, 12:33:50 AM
Reply #136
gman 82 aquasport
« Reply #136 on: March 18, 2013, 12:33:50 AM »
Also installed my new LED nav lights on the sides, which of course I had to cut more holes...
But they are supposed to be visable from 2 miles. :salut:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 18, 2013, 12:38:16 AM
Reply #137
gman 82 aquasport
« Reply #137 on: March 18, 2013, 12:38:16 AM »
I am trying to find some plastic caps to put over the bolt heads, because I know that my wife will want to park it up there in the summertime and let her feet dangle off the pulpit, so I have to make it sitting freindly :lol:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 18, 2013, 05:07:15 AM
Reply #138
« Reply #138 on: March 18, 2013, 05:07:15 AM »
Came out real nice Gman  :salut:
March 18, 2013, 10:02:54 AM
Reply #139
gman 82 aquasport
« Reply #139 on: March 18, 2013, 10:02:54 AM »
Thanks Rick, all this is a big learning experience for me, :scratch:  I've gotten fairly comfortable with the fiberglass and epoxy stuff :cheers: , but the stainless bending needs more help :eye: .. but I would try it again and probably will..I called the guy who built my rail dragster some years ago to see if he might could do some bends for me as he bends 4130 chrome moly for race chassis and has a mandrel bender but he didn't have the a way to put a 6 inch radius bend on 7/8 inch tube,very tight bend as he put it, his suggestion if I don't find someone, was to make 2 bent pieces and he would tig-weld them for me, so I do have a sort of option ..But I think I can find the piece I need somewhere on the WWW :study: This is why I post even my screw-ups , so maybe someone else will not have to do the trial and error thing :lol:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
March 18, 2013, 10:31:18 AM
Reply #140
« Reply #140 on: March 18, 2013, 10:31:18 AM »
Quote from: "gman 82 aquasport"
Have you considered counter sinking the bolts?
March 18, 2013, 11:19:33 AM
Reply #141
« Reply #141 on: March 18, 2013, 11:19:33 AM »
Quote from: "Blue Agave"
Then you could add a dab of 4000UV to cover the slight indent if you need it super smooth. :idea:
March 18, 2013, 01:55:37 PM
Reply #142
gman 82 aquasport
« Reply #142 on: March 18, 2013, 01:55:37 PM »
Great idea guys, and no I hadn't even thuoght about counter sinking the holes. :scratch: Flush would probably be better up there anyway..I'll post pics of how it turns out :thumright: Thanks :thumright:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
