196 Rebuilds
82 aquasport osprey 19.6 rebuild
8
9
10
Topic: 82 aquasport osprey 19.6 rebuild (Read 16658 times)
June 06, 2012, 05:17:28 AM
Reply #105
Re: 82 aquasport osprey 19.6 rebuild
Reply #105 on:
June 06, 2012, 05:17:28 AM »
Looks very nice - good job
June 26, 2012, 09:53:46 PM
Reply #106
gman 82 aquasport
Reply #106 on:
June 26, 2012, 09:53:46 PM »
Been a couple of weeks since last posting pics and info on the boat.....
Got it splashed in Lake Tillery the other week and ran it about 20 miles up and down the lake, everything checked out pretty good...had a little carb problem , but got the local johnson guru to rebuild the top 2 carbs( had to replace both bowls, warped), fixed a small fuel pump problem myself and took it back out to run it again and it was A-OK
runs about 33 MPH at 4900 RPM's, just trimmed up a little, the prop is more bottom end than speed...may look into changing, but not this summer...
On a previous post I talked about the fine line of balance that everyone on here refers to..Here is a couple of pics to illustrate the point....
As you can see by this transom shot the new drains are above the water line, with me (235 lbs) standing in the rear I still get no water in the boat.....the scuppers help keep the water out as it's loaded on and off
On this starboard side shot you can see that the boat sits rather flat in the water(was full of fuel,55 gallons) the drain for the fish box sits about 1 1/2 inches above the water line, the only time it's below is when both me and the mrs. are in the bow and I lean over the side to see the drain, it's about 1 inch below the waterline, so I have a removeable plastic plug I can pit in either end of the drain line....
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
June 26, 2012, 10:03:05 PM
Reply #107
gman 82 aquasport
Reply #107 on:
June 26, 2012, 10:03:05 PM »
On a brighter note, we took it down to Southport, NC the other weekend and splashed it in the ocean, ran out by Jaybird Shoals by Baldhead Island and out by Oak Island, only went a couple of miles away from the inlet this first trip, just checking things out....The Mrs.( Kathy) had a blast and informed me after getting back that we will be taking it down every weekend I have off( which is not but 4 weekends out of every 12, I work rotations of Sat and Sun) till the weather gets to cold...she has deciced that she could definatly live on a boat....
Weather was great and only 2-3 foot seas
On a not so bright note, failed my coast guard inspection at the ramp :( got my warning on what to fix...
1) my letters and numbers were not block letters
, has been changed now.
2) My hull ID #'s on the rear were gone :o due to the transom fix of previous owner, I have re-etched them back on the hull now
3) Gigged me on not having a back up map on the boat for the area(not required but requested)
Have one now for the entire NC coast..(have a gps)
Watched a bunch of boats get stopped by the CG and checked, alot of people out that weekend,....
Saw a boat get washed up on the shore because of either poor anchor hold or something, bad part was about 20 people standing around the boat in the surf and they did't try to push it back into deeper water and within 20 minutes it was on the sand......Hope they had tow coverage, not a good day for them, but reminded me to get a second anchor and rope.. :pirat:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
July 01, 2012, 10:08:36 PM
Reply #108
gman 82 aquasport
Reply #108 on:
July 01, 2012, 10:08:36 PM »
A good day at sea.
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
July 01, 2012, 10:29:10 PM
Reply #109
gman 82 aquasport
Reply #109 on:
July 01, 2012, 10:29:10 PM »
I took a few pics while I had the boat at the firehouse Sat. doing a little cleanup
I got our jackets up in a mesh bag ..out of the way..
one from the rear
Bow cushions, all of them snap in place
Same
New cushions for the console, the back rest one is 4 in thick so no bars in the back
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
July 01, 2012, 10:39:12 PM
Reply #110
gman 82 aquasport
Reply #110 on:
July 01, 2012, 10:39:12 PM »
Night time shots, boat still inside....
shot of each side lights under the gunnels.
front console lights
Lights from the bow
a from the stern shot, I originally had white leds in the boat, must say I like the blue much better, no glare..
light under the electronics box, no glare and it doesn't blind you and you can still read the compass
Front flood light, it's a soft light not to blinding
Rear flood...
I'm looking forward to seeing how it looks at night on the water
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 07, 2012, 10:56:07 PM
Reply #111
gman 82 aquasport
Reply #111 on:
October 07, 2012, 10:56:07 PM »
Been a while since I have posted any pics of the boat, been using it as much as possible, had it to the coast 3 or 4 times and we have it at the lake 1 or 2 times a week it seems. It will be down in Southport, NC for the Southeastern Aquasport get together this weekend..
We did name it this summer, for me the name is what I probably should have had for thinking redoing the hull and floor was going to be easy...( I would do it again to a 222 or a 24 footer)
For the Mrs.. it's what being on the water really is..
and a close up
The plans for this winter is to make an anchor pulpit with a drain pipe and make a storage area under the pilpit where the hatch is now....
Would like at this time to give everyone who has posted on here a big
for all the input and insight on my rebuild, learned a lot on this one and will probably do another in the future, just will take more time and it will be a little larger boat..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 08, 2012, 12:07:43 AM
Reply #112
Rigging Master
Reply #112 on:
October 08, 2012, 12:07:43 AM »
She looks great, and the bow cushions, Kathy has got to love! Kudos, sir! And...thank you for your service!!!
October 08, 2012, 12:11:50 PM
Reply #113
gman 82 aquasport
Reply #113 on:
October 08, 2012, 12:11:50 PM »
Yeah she loves having the cushions up there, every time we've had it at the coast or lake, no matter how rough it is and how much spray is coming over the front , she's up there having a blast
(as long as it's 80 or above)...I am going to try better to start posting more to others in the future, maybe something I learned might help someone else not have to redo something twice
Over all it was fun though.....must need more therapy
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 08, 2012, 12:57:03 PM
Reply #114
Purgatory
Reply #114 on:
October 08, 2012, 12:57:03 PM »
She looks GREAT!!
Looking forward to seeing her this weekend
October 09, 2012, 09:05:25 AM
Reply #115
gman 82 aquasport
Reply #115 on:
October 09, 2012, 09:05:25 AM »
Thanks gran, Looking forward to getting back down myself, only negative is I will be by myself 8) , the lovely Mrs. had to cancel her day off Friday to prep a class she has to give next week....so just me....and a few steaks for Friday night...I will get down probably around noon Friday...I think the next boat I try to find may be a 222 CCP, I like the way they look and the gunnel height... but that needs to be in a year or so, unless I run across a deal I can't pass up and just get it to do at a later date..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
October 09, 2012, 12:16:50 PM
Reply #116
Purgatory
Reply #116 on:
October 09, 2012, 12:16:50 PM »
Gotcha. You'll get to see two nice 222's this weekend
January 07, 2013, 07:30:46 PM
Reply #117
gman 82 aquasport
Reply #117 on:
January 07, 2013, 07:30:46 PM »
2013 updates...
Well I can't leave things alone
The winter project this year is a bow pulpit with roller to make 1 person anchoring easier
Then I plan to have an enclosure for the t-top made before season gets here..I am also changing the top from vinyl material to epoxied fiberglass for a hard top, it will make keeping the enclosed area dry much easier..here are a few pics of the pulpit taking shape 8)
this is the drain pipe for rope and chain
my bow roller, stainless steel
the thickness of the pulpit will be 1 1/4 inch
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 07, 2013, 07:39:00 PM
Reply #118
gman 82 aquasport
Reply #118 on:
January 07, 2013, 07:39:00 PM »
continuing on..
the wood with 6 oz glass epoxied between
sitting on the bow
it will run back to the lip and be secured with SS bolts thru the top with reinforcement under the cap.
from the front , it will be closed off across the front.
I have to decide which type of lights to use up front, mounted on the cap on both sides or mounted on the sides of the pulpit.
I will also modify the rail to go out and curve with the pulpit
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 08, 2013, 05:22:17 AM
Reply #119
Reply #119 on:
January 08, 2013, 05:22:17 AM »
Looks good gman
8
9
10
196 Rebuilds
